Aeroforce Interceptor Gauges ?
I'm thinking about getting Dual Interceptor gauges so i can display 4 things at once. Now the questions is what would be the 4 most important things to monitor- especially if you have a tune?
1. 2. 3. 4. I know everyone will have a different opinion and ideas so lets hear them! |
I monitor the following with mine:
1. Air Fuel 2. Intake Air 3. Coolant Temp 4. MPH (just because I don't like the analog gauge) |
I have a single Interceptor gauge in my car. :)
I have the auto-trans, and was hoping to monitor Trans Temp. and Actual Gear, but those are unfortunately NOT available. I don't know if Trans Temp. works for the Manual. I've emailed Aeroforce to try to get some help, but so far no results. I have been monitoring my IAT, and frankly it's not needed. With the stock air box, the IAT is always less than +5 from Ambient when you're moving more than about 40 mph. :nice: I have the LED Annunciator set to +230 Coolant Temp., and I monitor various other values, depending on what I'm doing. |
interesting...Well i dont have a auto and manual you cant read the temp on it.
I dont have the stock airbox |
1. A/F Bank 1
2. A/F Bank 2 3. MPH (****s and giggles) 4. RPM (****s and giggles) Once I get the blower on, I will change the bottom values to Boost and Fuel Pressure. |
Sweet so once i get a blower having 4 things to monitor will come in handy
I want to go with the BOSS gauge pod and put 2 of these in and then a single one just for boost eventually down the road. I was thinking 1. A/F bank 1 2. A/F bank 2 3. Oil pressure 4. Fuel Pressure 3rd gauge boost |
Keep in mind that you can cycle through up to 8 (IIRC) parameters on each gauge and non-essential things like boost can easily be added to one of your Aeroforce gauges with an analog 2-bar MAP sensor, instead of adding a seperate gauge. I usually display boost/fuel pressure and IATs/coolant, but change it up once and while.
^^ correct so instead of a 3rd gauge for boost what would you put in the extra spot in my 3 pod gauge holder?
do you have any pics of your gauges? also what color combo do you think will match the '11 interor the best? i was thinking white face with white lcd and black numbers |
3 Attachment(s)
^^nice... looking to do the samething just on top of the dash like the BOSS.
How do you run a dual gauge setup? Thought they plugged in to the Obd port
Originally Posted by drewzx3
(Post 6116025)
splitter connector to allow for 2 devices on the OBD
(Post 6116029)
Originally Posted by S197 GT
(Post 6115148)
Here's mine
Sorry for my ignorance, but would monitoring air/fuel ratio be beneficial with CAI and tune? |
Originally Posted by Hytek
Just when I thought I was done for a little while with mods I see this... Very nice! :hail: Is that the guage pod from AM? Sorry for my ignorance, but would monitoring air/fuel ratio be beneficial with CAI and tune? I think it'd be smart to monitor A/F on an NA setup because of all these #8 piston issues. You can see if you're running lean. However, this will average the A/F ratios across the entire bank, so it'd still be hard hard to determine if #8 is leaning out. |
(Post 6117281)
Good to know. Thanks. I think I'm going to consider these now.
How hard was it to install the pod? |
These gauges are straight cash!!! Did they come with the mounting harware? S197GT?
I got a Speed of Sound pillar, and these fit with friction. |
| All times are GMT -6. The time now is 04:32 AM. |
