2010 Mods
More mods to go with the Edelbrock SC on my 4.6L.. added the Roush 3rd link AntiWheel Hop kit.... added a MGW shifter... added a Shaftmasters Alum One Piece driveshaft... all installed by my boys at Watson Racing. Great mods, everything as expected and a professional insto job by Watson....!!!
Better lower control arms will help if that UCA doesnt completely fix wheel hop. Do you have wider wheels, with really good tires already? That can make a huge difference. Upgrading your radiator might be a good idea with all the extra heat a SC will bring. A full headers back exhaust should let you make a little more power while lowering your boost
Thanks for your info. So far so good on the wheel hop. Stock tires and stock wheels... (P255/40/R19). The SC has its own intercooler, but are you suggesting an upgrade to the factory radiator/cooling system? Right now I'm running 5lbs boost and I'm happy with the performance, anymore HP and I've got to be concerned about my internals....
Factory radiator upgrade, yes. If and when you upgrade the wheels/tires you will find out more on the wheel hop, as more traction can bring it back out.
