4 Attachment(s)
Just installed MonzterAuto's harnesses that make the tails light up sequentially when braking, locking and unlocking the car, as well as the turn-signal function
Attachment 192625 The install process: The single fastener that needs to be removed, then move that plastic panel away from the body to have access to the wiring: Attachment 192626 The factory tail light harness un-clipped from the body harness: Attachment 192627 The new harness installed inline: Attachment 192628 |
JMHO, but it looks like the emergency flashers flashing when you brake (as it appears to me). It could be confusing, and someone may not see them as brake lights but as emergency flashers, and they may not realize the difference until too late.
Originally Posted by 13GetThere
(Post 6816629)
1 Attachment(s)
Yeah, when I step on the brake pedal the side lights sequence outward then they stay lit, and then my third brake light pulses then stays solid too.
I'll have a new video soon ;) Meanwhile, I just got a couple new flip keys for the car :) Attachment 192576 |
How much did you pay for the Harness?
Where did you get the flip keys from and what did you pay for them?
Originally Posted by 14Glassback
(Post 6816749)
http://store.monzterauto.com/product...ight-sequencer
Originally Posted by FullRide14
(Post 6816762)
$21.95 each :) |
Originally Posted by Gabe
(Post 6815589)
Originally Posted by ardeshna
(Post 6817922)
This is awesome, thanks for sharing with the installation steps :hail:
Thank you, the link says it's only for 13's. But I imagine the keys are the same so I don't see why it wouldn't work... Fingers crossed!
Gabe how are the keys working out so far? no issues or concerns?
Originally Posted by mrc728
(Post 6827140)
1 Attachment(s)
Currently waiting to be installed: McLeod stainless steel braided clutch line, Amsoil 600-series DOT4 brake fluid, a new left rear axle seal and bearing, and some fresh Amsoil 75W140 rear axle fluid along with some Ford Racing friction modifier.
Haven't driven the car in about a week, since I found out about the leaking seal, since I'm pretty sure it's been leaking for some time and don't want to do further/possible damage to the gears. Appt for the seal repair currently made for this Friday Attachment 192097 |
Wouldn't the seal be covered by warranty?
(Post 6828720)
I wanted to change the fluid soon anyway, this will just add about an hour to the job, and not a lot more $$ |
9 Attachment(s)
Today I installed the new Ford Racing twin-65mm throttle body, running it for now off the twin-60 JDM tune, which they say is OK to do.
However, I can't push it much until I get a new tune for the new VMP fuel pump voltage booster First start-up: Attachment 191932 Attachment 191933 Attachment 191934 Attachment 191935 Attachment 191936 Attachment 191937 Attachment 191938 Was a little surprised to see this oil in the elbow ... guess I really need to think about a dual-catch-can set-up. Attachment 191939 Attachment 191940 |
12 Attachment(s)
Wow, I haven't updated this thread in a while ...
The twin-65mm TB didn't stay, I ended up removing it and sold it to my GF for her to put/use on her GT500. New AMR wheels test-fitted about 1-2 weeks ago: Attachment 189153 Attachment 189154 Roush lower grille delete kit finally installed yesterday, along with HomeDepot-bought black mesh behind it to keep rocks/other debris from hitting the heat exchanger: Attachment 189155 Attachment 189156 Attachment 189157 Attachment 189158 Attachment 189159 Attachment 189160 Man was I psyched to see it cleared the VMP heat exchanger, lol ... : Attachment 189161 New summer tires came in a couple weeks ago, should be mounted/balanced onto the new AMR's tomorrow, if all goes according to plan Attachment 189162 New 14" rear '13-'14 GT500 rotors are here, waiting to be installed along with new Hawk HPS brake pads and the new caliper brackets that relocate the calipers so the larger rotors will fit: Attachment 189163 Attachment 189164 |
looks like you are all prepared for the season ahead
Gabe, R u dumping the 18 inch wheel set up?, What prompted you to change to a staggered set up? Im amazed at how much you've done to your ride, very nice.
No there has to be more. LOL Looks Great Gabe. What did you not like about the TB?
