49 Attachment(s)
rMorimoto XB LED Projector Fog Lights
If you have already searched like myself and many others, you've probably found that there aren't many options for our foglights. You can: 1. Switch to a higher powered halogen or add HID and run the high probability of melting the plastic lenses/interior reflective material (even the lower 35w HID tend to melt the housings) 2. Switch to an LED bulb and lose all light ouput but get a nice color 3. Try to custom mount a universal, glass lens housing in place of the stock plastic one 4. Give up and stick with the stock bulbs THERE IS FINALLY ANOTHER OPTION FOR US!!! Through "The Retrofit Source" you can get these Morimoto XB Foglights for all GT500 model years. If you have ever looked into retrofitted headlights you know that Morimoto is a company that makes some of the highest quality projectors. Now they have a direct fit (plug-n-play) replacement for our crappy fog lights. The Morimoto XB mounts behind the bumper with all of the stock mounting points. They are powered by Nichia 5500k LED's that produce over 1200 raw lumens per side. The XB projectors concentrate a total of 2400 Lumens of pure white light into a beam that's super wide and perfectly distributed. The lens are made from durable polycarbonate and has a powder-coated cast aluminum housing preventing heat from damaging them inside. They also come with a 10 year Warranty!! I was super excited to find out that these were delivered within only 2 days of ordering!! Attachment 186685 As expected, the fog lights arrived packaged and protected by bubble-wrapped sleeves. Attachment 186686 The black housings and inside create an amazing "smoked out" appearance. Attachment 186687 The back of the housing feel super tough with the aluminum material. And as you can see, they have the stock mounting points as well as the standard 5202 plug harness making it 100% plug'n'play. Attachment 186688 I couldn't wait to get started and get these installed. To install, I removed my front bumper so I would have full access to remove the stock fog lights. After going through the full install, you could probably remove the lower splash shield under the car and get plenty of access to remove them, saving a whole lot of time. I had removed my bumper so many times to install different grills and headlights that I felt comfortable taking it off. If removing the bumper, you first need to remove the three bolts in the tire well of the front wheels. Cut the wheels all the way to the right to access and remove the driver side screws. Then turn the wheels to the left to access and remove the passenger side screws. Attachment 186689 Use either ramps or jacks/jack stands to lift the front of the car. Attachment 186690 Now remove the 5 screws from the underside of the lower splash shield. Sorry for the picture. I couldn't get the car up high enough to get it in one shot. Attachment 186691 Remove the 8 retaining clips holding the radiator cover in place and remove the radiator cover. Attachment 186692 Now remove the two bolts holding the top of the bumper cover on. Attachment 186693 Before removing the bumper, go ahead and remove the bulbs from the sidemarker lights and the fog lights. This is the scary part for first timers. Grab the bumper on one side where it meets the fender and pull out and forward. It will simply pop out of clips when enough pressure is applied. Repeat on the other side. Attachment 186694 Attachment 186695 Attachment 186696 From the front, lift the bumper cover over the two plastic retainers and now the bumper is free. Slowly pull the bumper toward you and place to the side. Attachment 186697 To remove the fog light assemblies, there are 3 plastic, circular retainers. Do not ruin these because they will be re-used. Each has 2 clips on each of them that have to be depressed to push through their holes. I found it best to use a flat head screw driver, unless you have a special tool for these. Push one tab in and put some forward pressure on it, then push the other tab in and it will push right through the hole. Attachment 186698 Attachment 186699 Attachment 186700 Attachment 186701 You will remove the three retainers from the stock fog lights by just pulling them off by hand. Attachment 186702 You will also have to remove and reuse the vertical leveling screw in the bottom. Attachment 186703 Remove the retaining clip that you just removed the screw from. With the flat head screw driver, push one of the clips inward and it should just pop right out. Attachment 186704 Attachment 186705 Attachment 186706 Attachment 186707 Now install the retaining clip into the square hole in the XB fog lights by applying some pressure. It does not go down flush until you begin to screw in the leveling screw. Attachment 186708 Attachment 186709 Attachment 186710 Do not screw the leveling screw all the way in. Just enough so that it is threaded into the clip. Attachment 186711 Attachment 186712 Put the 3 circular retaining clips on the mounting points of the XB Fog lights. Attachment 186713 Insert the fog light from the front of the bumper and line the clips up with the three holes. Attachment 186714 Attachment 186715 Push in with just a little pressure and they will snap into place. They may feel a little loose since we have not tightened the vertical leveling screw tight. Go ahead and tighten the screw until there is little play in the fog light. Attachment 186716 Here are the XB Fog Lights installed. The black smoked look is amazing!!! Attachment 186717 Now just repeat in reverse to re-install the bumper. Line up the front bumper cover and place the 2 holes on top over the black retainers. Attachment 186718 One side at a time, re-fasten the sides back level and flush with the fender. When pressure is applied you will hear the bumper attach to the clips. Attachment 186719 Plug in the 5202 adapter from the XB Fog Lights right into the fog light harness. Just like the 5202 bulb, you will see 2 vertical slots on one side and 1 vertical side on the other to line them up correctly into the harness. Also plug the side markers in. Attachment 186720 Before fastening the lower splash guard, put the car back on the ground and use a phillips screw driver to level your fog lights even with each other. This is a lot easier without the splash guard and tire wells sealed up. Attachment 186721 Now just reinstall the bolts into the lower splash guard and inner tire wells. Like I said earlier, it would probably be easier and doable to just remove the bolts from the lower splash guard and inner tire wells to access the fog lights. However, I wanted to get a good and detailed look for the installation to be able to post pictures. The stealthy smoked look is amazing on the car. And you never have to tint them like you would with the OEM chrome ones, which dramatically decreases the light output and makes them even more useless. Attachment 186722 Attachment 186723 The crisp cutoff is amazing as is the output of these lights. You can tell from the picture how wide the beam is and how intense it is all the way to the left and right side of the beam. This is great at night and you gain so much peripheral light. Here is a picture with just the XB Fog Lights on: Attachment 186724 Attachment 186725 Here are a couple comparing my Retrofitted Headlights with Morimoto projectors and 55w HID with and without the fog lights. Keep in mind, my headlights are going to be a lot brighter than OEM HID because of the retrofitted projectors and 55w HID. So everyone else will see a more dramatic difference. Headlights: Attachment 186726 Headlights & Fog Lights Attachment 186727 Headlights: Attachment 186728 Headlights & Fog Lights Attachment 186729 Headlights: Attachment 186730 Headlights & Fog Lights Attachment 186731 Headlights: Attachment 186732 Headlights & Fog Lights: Attachment 186733 You can tell the major advantage of these is the wide beam, which is where you want fog lights to light up since the headlights start losing intensity at the edge of the beams. I am so glad that someone finally brought an option to us for our fog light replacements. And these are not cheap replacement assemblies. They are high quality Morimoto Projectors!! Here's the link: http://www.theretrofitsource.com/com...rd-4-inch.html For a limited time, use the discount code "XBGT500" they set up for $25 off!! |
Excellent write up!!!
Outstanding write up very impressive
Originally Posted by atgonzales
(Post 6948719)
Wonderful write up. You left NOTHING out that I could see or read. You must have spent more time putting your post together than installing your lights.:salute: By the way>>>>> They look Great! I can see from your pics. That you live in a rular area. Thats where you need them more than ever. I'm in the same boat. My roads all have drainage ditches that run along with the roads and the wildlife is always on the move. Again....Verry clean look.:hail: |
