Project Twice Bitten First built by SVT, now rebuilt by SVP!
timing
Old May 29, 2013 | 03:49 AM
notchos 90's Avatar
timing
Gt40p heads, e303 cam,1.7 r/r, u/l gt40 (explorer) intake,egr spacer, 65mm t.b, 70mm maf,19# injectors, ford racing shorty headers, H pipe and dumps,4:10 with a shift kit and a 3000 stall converter aluminum drive shaft . What would be a good timing set point for this set up?
Thanks.
Old May 29, 2013 | 04:49 AM
onebadvert's Avatar
You can probably run up to 14* but may have to run premium fuel. Every degree of timing will be worth a bit if hp. Just pay close attention to spark knock. If you get to the point where there is spark knock then back it off 2* and you should be good. You can check for spark knock by loading the engine. For instance try going up a hill in 4th gear at about 25 mph give or take. This will load the engine when spark knock is most likely to occure
Jim74656
May 1, 2023 02:15 AM
Feffman
Aug 22, 2015 06:27 AM
Feffman
Midwest
Aug 15, 2015 08:08 AM
roushcollection
Jul 28, 2015 02:08 PM
Sacmus
Jul 22, 2015 02:59 AM
