Originally Posted by twokidsnosleep
(Post 936771)
No it was the other dealer....not much better result unfortunately. :banghead:
Originally Posted by Hollywood_North GT
(Post 937135)
Cam Clarke...? :what:
Trying to be diplomatic and not name names.....but yes |
I did a thorough wash on the weekend and really sprayed the passenger side to see what would happen. No carpets wet, but passenger door seems to be
dripping water from the front drain hole like it is still full. Water was sitting on the pass side sill plate when I opened the door. I think I am just going to have to live with this, be careful and watch out for long rainy drives, like those don't ever happen in Vancouver. :banghead: Good news is the driver sill paint looks great :nice: and I hit 6,500km's today |
Water on the door sill has nothing to do with the drain holes. The dealers try to tell you that water on the sill is normal and that it's coming from the drain holes but that is BS. Look at the position of the holes in relation to the sill. They are below the top of the sill and the door gasket is between them.
I believe the problem is due to the frameless windows. Water is getting in at the top of the winds where it meet the gasket. It then runs down the gasket to the edge of the door (where the latch is) to the bottom where it drips onto the sill. It is held in by the door gasket until you open the door. |
water leaks
I am in for the second time now to get to the root of wet carpet in the passenger front foot well. Was told yesterday that after repeated checks and tests the side mirror in the passenger door has a seal leak. As I wait for parts I wonder if this is the end.
:doh: I have always noticed water sitting on the passenger door sill after a wash but untill a few weeks ago never had wet carpet. :dunno: The service tech is going all out to get this resolved. |
1 Attachment(s)
Originally Posted by mbkintner
(Post 1002770)
I got mine repaired last November per the TSB. The guy who fixed it was the dealers '"leak expert" and said it was a cowl grommet that was the culprit in my car. The service writer said it was the first one they had seen at the time, although he told me the other day that they have done more of them since.
Originally Posted by YaoNYC
(Post 828768)
my bad....check out this thread...
http://www.mustangforums.com/m_2076816/tm.htm i was told on many 05 cars....some 06 cars...then a few 07 cars?? thanks! |
Hey y'all, I'm new to this forum and joined specifically for this water leak issue. I found the answer in another thread and for those who still have issues - let me tell you about mine.
Last Thursday I had the wifeperson in the car and it was raining the perverbal cats and dogs. I accelerated from a traffic light and the wife got a shower from under the dash. This was the first experience with this issue. As soon as we got home I pulled the mat and smelled the carpet (looking for a radiator smell, nothing just plain water. I went on line to see if anybody else had experienced this problem, let me tell you hundreds had. I searched several TSBs and several Mustang forums, then the answer popped up. The proplem is with the drain hole located just to the center of the car by the A/C heater inlet. Turn on the ignition and turn on the windshield wipers when they get to the upright position shut the ignition off, then remove the right side (passinger) cover by removing the 3 plastic rivets, and gently lifting up to clear the upper catches move to the center and out. You will see the filter to the air intake for the AC/heater, put your hand in and move it toward the center you will feel the drain plug, you will also see that if is full of junk. I used a long screwdriver to clear the drain, then some very MILD bleach water to kill any bacteria and flushed it with clear water several times. Once you know the issue, it becomes a maintenance issue. I figure maybe 3 times per years and it should take 10 minutes at best. |
