Originally Posted by vistablue mustang
(Post 887188)
All is good so far, it rained hard last week and my stang sat outside for about 7 1/2 hours and I drove through it too. Checked gromit, wires, and SJB all were dry.
Now you just have to keep an eye on the prematurely dying battery issue... ...oh, and that crackling sound from behind the center gauges. :grin: |
Originally Posted by Hollywood_North GT
(Post 887466)
Maybe they actually got around to fixing it on our cars, Tom. :nice:
(Post 889818)
Torrential down pours for central NJ today, believe me when I tell you if my car was going to leak it would be today. Checked while I was parking today all was dry. I will check fully when I get home, though I am pretty much going to say I am a-ok for this problem. I just don't think that after all this (my accident) my luck could be THAT bad.
Has anyone noticed this problem getting worse after it first starts? Originally I only had leaks if I drove through a touchless carwash that had an underbody spray. Now I have a problem whenever it rains. I don't even have to be driving it. Merely siting in the driveway results in a leak.
My 06 leaked in two places. One was a seam that wasn't sealed correctly and the other was at the base of the windshield. It took two attempts to fix. So far knock on wood everything is dry. Mine never got the carpet wet on top or made it over to the SJB. It just soaked the firewall foam and the pad under the carpet. If I hadn't read about it over on mustangforums I would have never know I had a leak until it started smelling. According to what I have read any car made after 10/06 has this problem fixed.
Mine leaked on the passenger side also it would get water into the junction box and my key fob would not work, I could still start the car but had no brake lights or speedo I think it just affects what ever fuses get wet. After I would let it dry out everthing seemed ok. Dealer replaced junction box and pad under front carpet and supossedly fixed the leak but it hasn't rained since for me to tell.
Well my vert is going back for water leak check. The passenger floomats are ok, but the passenger door and door sill are always wet. It seems like the door is full of water; drips on opening and drips onto the sill. Anyone have something similar???
Scott :banghead: |
Originally Posted by twokidsnosleep
(Post 907955)
Scott :banghead: Do you have a pic? |
(Post 907955)
Scott :banghead: |
I have noticed twice that after washing my car there were drops of water on the inside of my driver's side quarter panel window.
Originally Posted by DoctorQ
(Post 907989)
Each door has 2 drain holes at the bottom of door. Some S197s have both drain holes plugged (with plastic grommet).. others 1 or none. Just a shot in the dark here, but if you have both holes plugged, try removing and see if they drain properly.
The rear drain plugs are there on both driver and passenger sides, but the more forward drain slots are open on both d and p sides (no black plastic cover).
There is way too much moisture and condensation on the sill when I open the passenger door and the door seems to drip all time...worse when raining. Try to get a couple pics on the weekend. |
(Post 907989)
I only drive my 47 coupe when the weather is bad BUT you guys still have me worring. The old 60 yr. old Ford doesnt leak
door full of water
Well she is back from the dealer, apparently the door drains were clogged with pine needles....my house IS surrounded with trees, so it is a plausable explanation. They apparently removed some plastic cover to allow the door to drain more freely. Why was the cover there in the first place then? :dunno:
We shall see with this weekend's wash and wax fest. |
(Post 928855)
Originally Posted by mbkintner
(Post 930709)
See my post 3 posts up regarding these drain holes. Several dealers seem to be trying to convince owners that these drain holes have something to do with the leaks. I say that's complete :bs:
Yes sir it is complete BS....it has been raining like heck here this week and the passenger door sill is soaking wet and the door continues to drip from the 'fixed' drain hole. It is a rust trap IMHO :shame: |
so sorry to hear this still hasn't been resolved yet, Scott. :shame:
(Post 936275)
(Post 936716)
Scott - you're not still going to those idiots out at Coastal in Burnaby, are you?
No it was the other dealer....not much better result unfortunately. :banghead: The first one is going to get my sill painted this week, so that is good. :nice: I haven't had the HUGE passenger side leak that started this all out, but I have avoided driving the car the same conditions as when that happened...b/c I know she is leaking over the sill and a longer drive in a big rain will flood the passenger side. Love this car, but Ford really has f-up'd the water seals on this thing..and can't or won't solve it. |
