Spark plugs
Old Mar 20, 2023 | 09:51 PM
Gak's Avatar
Gak
Spark plugs
Could someone suggest some quality spark plugs for an 08 GT?
Old Mar 20, 2023 | 10:06 PM
05stangkc's Avatar
Just Incase You Want to Know How to Properly Remove those Boogers. Plenty of Spark Plug Debate in Here as Well! Even With all the Debate I would Go Back With Motorcraft Oem Plugs. That's My 2 Cents! Read On And Research!
https://themustangsource.com/forums/...ite-up-522706/
KC
Old Mar 21, 2023 | 01:24 PM
m05fastbackGT's Avatar
Hello and just an FYI: We also have a search function menu on this site... All that is required is to scroll up on the home page, click on the search tab, and when the drop-down window displays, type in "spark plugs" You should then come across all the thread submissions directly related to the spark plug topic... In the meantime, hope you'll find the information provided as useful and welcome aboard!
Old Mar 22, 2023 | 07:09 AM
NC14GT's Avatar
I replaced my originals in my old 2007 GT/CS (at about the 60k miles mark) with 2 boxes of these in early 2022. They were perfectly fine. I agree with 05stangkc about getting Motorcraft.
Old Mar 22, 2023 | 07:48 AM
LOL!
Old Mar 22, 2023 | 04:50 PM
If the OPs "08" GT has the revised heads with brown coil boots for the standard 12mm one-piece design spark plugs, I agree with both of you guys on sticking with OEM Motorcraft spark plugs... However, on the hand, if the OPs "08" GT still has the older style heads with black coil boots for those dreaded 16mm high-threaded 2-piece design spark plugs that are well known for breaking inside the heads during extraction, then respectfully I disagree, and would instead recommend upgrading to either Brisk Racing one-piece design spark plugs or MSD and Accel one piece design spark plugs... Links are provided below if interested...
https://briskracing.com/collections/...7ys-spark-plug
https://briskracing.com/collections/...17c-spark-plug
https://www.holley.com/products/igni...gs/parts/37164
https://www.holley.com/products/igni...ugs/parts/8160
muscledom
Aug 14, 2013 06:51 PM
MyFirstMustang
Aug 20, 2012 11:53 AM
