SHAKER 500 CD ERROR
My radio has had this "cd error" message before. I have cleared dtc's by using the #3 and #6 preset buttons to access the dtc and clear them. and it worked the time before. However, this time, it will clear dtc, but continues to not operate. Just says "intializing" and then nothing.
I have scheduled a service appt, but they are warning me that depending on the cds in the cd player, that warranty may or maynot cover the labor and parts. Does anyone know how to manually remove without causing damage to radio and cd's? |
Sorry wouldn't be able to help really... But if you need a new unit I kept my old unit from my 05. Willing to sell if they are charging u arm and a leg... works perfect.
Is it a manufactured CD or a burned CD that is giving you trouble?
When my Shaker failed, it gave the exact same error and had nothing to do with the type of CDs loaded... as none were installed. Not sure how they can not cover it due to the type of CD being used??
Originally Posted by Doogie
(Post 5934216)
combination...manufactured and burned...4 or 5 cds in deck. (mp3 files on burned discs)
Originally Posted by FERRARIGRL
(Post 5934310)
How else would you be able to use the MP3 feature. Where do you buy an MP3 disc? I only make mine.:dunno: So how could that affect the warranty... It can't. |
I got a used Shaker off eBay a couple years ago for $150 or so. Probably cheaper now. But I look at it this way: Perfect time to upgrade (and this isn't the first time I've recommended this). They've got a lot of nice after-market decks for very reasonable prices, and I'm not talking about the $1000 touchscreen decks that seem to be so **** popular on this forum. I got a nice Pioneer deck for $350 that does MP3CDs, Bluetooth (comes with microphone), Bluetooth audio, USB input (iPod, thumb drives, etc), and an aux jack. Sounds great too, and wasn't that difficult to hook up. Trust me, I did the Shaker 500 for 2 1/2 years. Got so pissed at it I punched it. There are much better options out there than buying another one.
Originally Posted by Cavero
(Post 5935586)
If the repair or exchange is free, it is still cheaper to go that way for now. The warranty on my Shaker ran out last week, but I've never had a problem with it. If mine dies though, I am going aftermarket for sure. |
After almost 6 years, my Shaker 500 system started acting up today. "CD Error" started up and I have 4 CDs trapped. How can I recover my CDs and is there a quick fix I can do?
When I had mine replaced, for the second time, Ford had to send the radio back to its manufacturer to have the cd's removed. I would definitely look at after market radios if you can because the last time mine was replaced, the Ford Tech indicated that they have had quite a bit of issues with the Shaker 500 for this particular reason. Good Luck
I just replaced my Skaer unit in the fall. Got soooooo sick and tired of it spitting out CD's, CD's not working and such.
Replaced with a Kenwood DNX8120, touchscreen, NAV, the works. Only 1 CD/DVD in at a time, but I have my USB stick plugged at all time with lots of music. GET RID OF THE SHAKER! |
Originally Posted by kryptonite
(Post 6010835)
Originally Posted by azoufan
(Post 6013885)
Take the radio out, remove the front bezel, plug the connectors in the back and turn the key to accessory. Rotate to each cd and hit eject, then insert a flat screwdriver in under the bottom of the cd and put pressure on it towards the top of the cd player, then drag it out. If you do it carefully or tape up your screwdriver, you might get them out without damaging them. As for me, I already had the cd's ripped, so I mangled the holy hell out of them just to get it done. :nice:
The last time I had mine replaced the tech that did it got the CD's out in nothing flat. This was a vendor that came in with the replacement units and not the dealer tech.
I was going to live with the replacements until the unit killed my battery while the car was parked at the airport lot because it was continually searching for the CD. I went with a Pioneer Nav system. |
Add mine to the list of cars that have had this problem, just before I am going to sell the car too... :(
