S197 Overheating and cooling fan problem source
Old Sep 24, 2025 | 09:21 AM
Dark Drop Top's Avatar
Originally Posted by Bert
check your tuner: pretty sure the fan on settings is one of the user adjustable parameters
go in to the area where you load the tune; then go to "adjust parameters" or whatever it is called; look through the settings to see if you can find the fan on temps; I'm pretty sure it is in there. Then you can see if it is set to some crazy low number; and you can adjust to a higher number if you want. I am not sure what the factory settings are, but I think the low fan is around 190 and high fan around 210 or something like that
That's a good idea,but I think it fixed itself.
It didn't come on when I started up yesterday after sitting for about 3 hours.
I'll be doing a cold start in about an hour,so I'll know more then
Old Sep 25, 2025 | 11:01 AM
Didn't hear it come on after my cold start,or after work,or even after sitting for only 90 minutes.Looks like it really did fix itself
6-Speed
Aftermarket 2005+ Mustangs
17
Oct 29, 2015 04:42 AM
Matthias
Apr 30, 2007 11:25 AM
05retro
2007-2009 Shelby GT500
Aug 2, 2006 01:38 PM
Auburnman
21
Nov 23, 2005 10:41 PM
