-   Repair and Service Help (https://themustangsource.com/forums/f739/)
-   -   power steering noise (https://themustangsource.com/forums/f739/power-steering-noise-452690/)
fast frankie May 24, 2007 01:39 PM
I have a noise comming from the power steering. It can be heard when I am stopped and turn the wheels left or right. It is a high piched whine that can only be heard from inside the car. Anyone else have this problem?
DoctorQ May 24, 2007 04:55 PM
If you haven't done so already, you may want to check the PS fluid level. Also, check out this thread: http://forums.bradbarnett.net/showth...steering+fluid
hawgman May 29, 2007 10:32 AM
My power steering has been making noise also. At first it was a squeaking noise with the car sitting still, just slight movement on the steering wheel. Kind of the noise tires make on a garage floor. The noise got louder over a couple of weeks. Then the next symptom was a chirping noise when the car first starts up, like a pulley making noise. Today I noticed the power steering wasn't nearly as "assisted" as it used to be. So I popped the cap on the PS fluid reservoir and there is no fluid movement what so ever in the reservoir. I am suspecting that the pump and the rack have probably both crapped the bed. I know of several other people that have had the power steering go out on their Mustangs also.
fast frankie Jun 3, 2007 09:25 AM
Let me know how you make out with thw dealer. I am going in next week mand I am sure they will scratch their heads as usual.
fast frankie Jun 7, 2007 11:09 AM
Took the car into the dealer and it was the upper steering shaft that had to be replaced.
