MPG Problems
Re-read Doctor Q's post above. You DONT need IUP, just push the stupid reset button on the odometer. Be consistant with your checking. IF you are correct, then it's probably just a sensor. I'm betting your not. Drive it like you owm it, not like your renting it. If it doen't improve then do the reverse.
My average mileage over the last 24,000 miles, according to the computer is about 18.5 MPG.
You may have only been in ten MILES of bumper-to-bumper. But the real question is how many minutes or hours you sat in the b-to-b traffic with the engine idling away. If that ten miles took two hours (been there and done that too), that is more significant than if that ten miles took 15 minutes.
How did you calculate it? Not saying you are wrong, but if you filled up the tank, then drove 50 miles, then filled up again, you won't get an accurate estimate due to variations in how full the tank was to start, how much you put in after the run...etc. When you average it out over an entire tank you get a much more accurate result.
That said, people are getting 25mpg on the interstate because that is what these cars do. Something is wrong with your car if you are getting 14-15.
I filled up the tank this morning...15gallons... drove 50 miles on the interstate...used up a quarter of a tank = 3.75gallons. 50miles divided by 3.75 = 13.33 MPG... = Something is wrong!!! I rounded up when I said 14-15 assuming that they is a lil user/guage error!!
Even if you put in a little more the second time (1/2 gal.), you still haven't broken 15mpg.
I've never gotten less than 17 ever.
Something is wrong for sure.
Ok....so now I have double checkked my problem within this weekend, i know it is something. Has anyone else seen this problem before? Anyone have a suggestion on what to tell the dealership the problem could be? .... I love my car....I just wish I could figure out this problem!!
From there, I would assume your car's PCM would be checked for any outstanding codes, the air/fuel ratios examined, and other standard diagnostic checks related to drivability issues.
It would be difficult to suggest what a potential problem might be without further detailed information about the engine's operating state.
I'm not sure if you've tried this but the only way to calculate accurate mileage is over the course of an entire tank of gas. Run it until the gauge is almost at E, then fill up. divide miles driven by total gallons purchased. This gauge estimating stuff is no good, the gauge is not exact and can be several gallons off.
Steve is right.
If you want to accurate calculate MPG, start from scratch and max out the gas tank. Reset the trip odometer. Drive around until you need to fill up on gas. Record the # of miles from the trip odometer and the # of gallons needed to max out the tank. Miles / Gallons = MPG. People recommend taking the average of 3-5 fillups, but I keep a log of every fillup and just plot it on a graph trying to find correlations between ambient air temperature and driving schedule to see its effect on gas mileage.
This may sound rediculous, but. Is it breathing? I know it is new, but, open up that air box, and give it a check. You just may have a bad filter.
Sounds to me like it is an air/fuel ratio problem. Of course if it were mine, I'd fix it right: CAI/Exhaust/Bama tune!! Then she'll, breathe, perform, and you WILL get the best mileage ever, because it will be done right. IMHO
I would say you do have a problem. I got over 25 mpg (yes it is according to the computer but I can say mine is close to accurate) yesterday from Lakeland to Clearwater. I don't know if you are using the cruise control or not, but I do know it makes a few mpg difference when I do. (Heavy foot on overpasses and overtaking)
Also, I get around 16 mpg during my daily commute up and down US 19.
I always run the car everytime to almost empty and reset the Trip computer, so that I may calculate my MPG. I am averaging 15gallons per fill-up and 230total miles on a tank = 15.33MPG. Everytime I drive I-4 & I-75 I use the cruise control, but on I-275, people drive to crazy to be able to depend on a set speed.
Don't know which dealer you use. BUT, regardless, of the big three in Tampa. Go to Brandon if you do not get results from your selling dealer. Not only is their service performance oriented, being the largest ROUSH dealership, they have taken care of a lot of us TMS guys.
