Massive battery drain
Hi all
I have a 2005 Mustang GT. About 110,000 miles on it. It's in pristine condition and I've never had any issues with it. However, suddenly out of the blue, my battery is getting completely drained while it's off. No lights left on, nothing. But after a day or two, it's so dead that not even LEDs will glow. After charging it back up, I check around for a culprit but come up empty handed. Are there any common things on these cars that could be the cause? Otherwise any ideas where to start? I'm good with electronics and wiring but have never had to track down a draw before. Thanks |
We Have Tons of Threads on This Issue. So Much To The Point of Where Do I Start.
Moved You To Proper Section! Realize I Like To Answer Some Threads in a Broader Context In That I May Address Things That are Not Your Particular Issue But Maybe Useful To The Next Reader. Well Today I'm Going To Start With The Basics. Because I Just Went Through This on My F-150. In it's Case it Was an Internal Short in The Battery Due To Age. Charge it Up It Starts and Let Set and it Was Dead Again. So First Things First Do a Test on The Battery to Check For Cranking Amps after a Good Full Charge To Make Sure it is in Good Condition. {NOTE} While The Older a Battery The More Suspect it is For Internal Drain, which is Caused By Contaminants Shorting The Plates Inside it Can Happen at Anytime as They Are Just Floating Around inside Battery. A Crank Test Will Tell The Tale. I Recall over The Years Working at The Various Dealerships We Would Get New Cars That Sat on the Lot For a Long Time and The Battery Would Fail Before The Car Even Sold or Shortly Thereafter. Car Batteries Hate Sitting! If You Don't Have The Equipment Many Parts Houses Will Test Batteries and Check Codes For Free. While You Are At it a Good Code Reader Which Could Check For any Codes {ALL CODES NOT JUST P-Codes} at All Would Be Useful. If Battery is Going Completly Dead in a Short Period Codes May Get Cleared So May Need To Put Some Drive Time on Car Before Checking For Codes. So If We Rule Out Just a Battery Issue We Then Try & Find What Has Changed Since You Did Not Have Any Issues Before. Has Anything Changed Recently. Added or Changed Something Electrical? Stereo Etc. Any Kind of Repair Work?? Car Recently Was Exposed To a Lot of Water?? Water Intrusion at Cowl Can Cause Many Issues. Car Was Made a Weekend Car Vs a Daily Driver?? Many With S-197's Simply Have To Use a Battery Tender If Car Is Not Used Much! Bad Alternator. Really a Lot of Different Causes and I Think We are At the Point Where We on The Site Simply Go To The Last Culprit on a Post So I'm Trying To Steer Towards a Back To Basics Approch This Time Around. Take a Look At The STICKIES in This Section and There a Lot Are On Battery / Alternator. As Far as Your Question on Chasing a Parasitic Loss Here is The FORD Guide. https://themustangsource.com/forums/...ompany-549893/ Kc |
Thanks for the response and moving to the proper section.
That's my frustration. Pretty much the answer to all your questions is "no". The battery is less than 2 years old, and I have a battery tester. It passes crank and amperage tests. No repair work has been done for a few years. The audio system is original. I put an aftermarket head unit in it about 6 years ago. It's driven regularly, although not every day, since I work at home. The alternator is only a few years old and works and charges great. This just started out of the blue a month or two ago and the battery is suddenly drained to fully dead in a day or two. I can't find any cause. |
Ok So I Would Check Out The Parasitic Loss Pdf & Proceed. A Little Twist on The Alternator if I Recall is They Can Test Good and Still Have a Bad Diode & Cause a Loss. I Think a Thread Here I Will Post in a Sec Will have Some In Depth Alternator Info. I Would Just To Be Sure Check For P-Codes and Body Codes Even If You Don't Have a Check Engine Light To Narrow Down Search! If You Do Narrow Down To Alternator it is Imparative You get a Good Quality One & Might Also Look into The Denso Upgrade!
https://themustangsource.com/forums/...-phase-539499/ KC |
Found This Info on Rock Auto.
Paragraph 6 Seems Interesting!https://www.rockauto.com/Newsletter/images/RAmech.gif When the battery goes dead, the condition of the battery and the alternator are two of the first things to check. However, do not assume that if the battery is good then the alternator must be bad and the cause of the problem. My 1979 Chrysler 300 still has its original, never disassembled alternator. I have lost count of how many new batteries and electrical problems the car has had over the decades. Here are a few tips on how to use common tools to diagnose charging system problems to prevent unnecessarily replacing the alternator. These are general suggestions that may not apply to every car. Rely on your car’s repair manual (found under “Literature” in the catalog) for vehicle specific instructions.
Thanks again for the info.
I will go over the components a bit more carefully. Hopefully it's not the alternator as this is the one I have in it. It is quiet, smooth, and charges it up great at about 14.5v while driving (I have an in cab voltmeter). https://www.americanmuscle.com/paper...or-0510gt.html |
You Are Welcome!
If You Do Have an Alternator Issue There Are Still a Few Shops Out There That Can Rebuild Your Existing Unit. Just a Thought if That Happens! We Get So Used To Simply Exchanging Parts These Days Due To Time Issues Etc. We Don't Usually Think Around Those Lines! KC |
Hi, I did not read all of the above, so apologies if I am repetitive:
One common cause for this is the Shaker stereo system. One simple trouble-shooting method, is to pull the fuse for the radio/stereo system, and see if the draw goes away. Check the owners manual for the fuse number(s) and be aware there could be more than one. Another way to test, is: disconnect the battery ground; and put an ammeter between the ground post on the battery, and a chassis ground. You should see the draw on the ammeter. Remove the fuses one by one, until the draw goes to zero. Now you have identified the circuit with the draw. Next you need to figure out what on that circuit is causing the draw; and in the meantime you can leave that fuse out, assuming it is nothing vital. |
| All times are GMT -6. The time now is 12:45 AM. |
