-   Repair and Service Help (https://themustangsource.com/forums/f739/)
-   -   Interior Rear Rattle Fixed (https://themustangsource.com/forums/f739/interior-rear-rattle-fixed-438488/)
Mark S. Aug 4, 2006 08:11 PM
I'm removing my posting...the rattle is back!
2005GTDELUXE Aug 5, 2006 06:05 PM
what did you think that they did before that may have stopped it.
Mark S. Aug 6, 2006 12:10 AM
I thought that the rattle was coming from my driver's side rear seatback since it was not fully latched...the rear seatback is now fully latched and it's seatbelt is secured tight between the seatback and the rear armrest area, however, the rattling/creaking continues whenever I hit a bump in the road. It's back to the drawing board. I also pressed in the C Pillars in the rear in case they were the culprits contributing to the creaking noise. On my way to work today...the noise appears to have stopped...for how long...I don't know...darn gremlins!!:banghead:
2005GTDELUXE Aug 6, 2006 07:38 AM
this is the answer
SoFlaBoss Aug 6, 2006 07:53 AM
Try checking out inside the trunk, where the liner attaches to inside the rear quarter panels with push-pins, in the top section of the liner (both sides). I replaced my rear bumper cover the other day and noticed that this push-pin fits into a clip that is loose, which rattles metal against metal, possibly squeaking too. Just tap on the inside liner a little and you'll hear what I'm talking about. Just a thought.
Steve
Mark S. Aug 6, 2006 08:27 PM
SoFLO5GT, I'll be sure to give that a shot...it's amazing...the noise seems to come and go. It was fine this morning as I drove home (about 20 miles)...since I was just below a half tank of gas I decided to stop and fill up...once I did that, the noise returned...there are times that it can really drive me nuts...however, with the music on (even only a quarter volume), I can't hear it. Sounds more and more like creaking, than a tapping. Go figure!:drool:
svt boost Aug 11, 2006 03:50 PM
i have the same problem!
it happens paradoxically for me on bumps, and not all of the time. I cant tell what the **** thing is!
05gtIn408 Aug 13, 2006 01:17 AM
..I too have the dreaded squeak/ rattle coming from the rear of the car and its driving me mad trying to find it but it does sound like its coming from the rear of the car I'm thinking of putting in some sound deadner in my trunk and some other spots to see if it at least that will cover it up since i cant seem to find where in the rear its coming from...
Tboned Aug 14, 2006 10:05 AM
Mine was an exhaust shield rattling..
icemant180 Aug 15, 2006 11:42 AM
check the plastic cover over the trunk lock assembly. Mine was rattling when I cranked up the shaker. A small piece of duct tape placed on the back side where it can't be seen did the trick.
lethaljay Aug 15, 2006 07:38 PM
I also experienced this same rattle for the longest time and it made me furious! One day I hopped into the back seat and banged on the back ledge under the window and realized every time i banged on it, it would rattle. I then crawled into my trunk and banged on the ledge from the underside. I found a small section where it looked like a tack-weld didn't get fully umm 'tacked'? I then bent the corner in a way that the rattle was completly removed.
Mark S. Aug 19, 2006 07:49 AM
icemant180 and lethaljay, I'll give it shot...thanks!
