Heater issue 2012 V6
I just recently noticed that in the mornings my windows would fog up. Living in GA I rarely use the heater other that to get the moisture off the windows. The A/C works fine but if I turn off the A/C the air temp is the same temp or room temp from blue (cold) red hot. Any ideas?
I do have an extended warranty but there is a $100 deductible. |
Could be temperature blend door actuator has failed or door shaft is broken.
You can also check Battery Junction Box (BJB) fuse F4-30amp. Smart Junction Box (SJB) fuse F45-5amp and F15-10amp for power. |
I will look at that. I am not much of a mech.
| All times are GMT -6. The time now is 06:26 AM. |
