Grinding in Second Gear
Old May 28, 2007 | 07:26 AM
DavidM's Avatar
Ok so I have determined that the car needs to go in to have the transmission fixed due to the massive grind in second gear when shifting above 4500 RPM, and on the down shift in high rpm.
My question is; Is is necessary to remove all my mods from the car and take it back to stock? I know I will need to put my factory shifter back in, but other than that I am not sure. I have UDP's, Off road H, C&L CAI with brenspeed tunes, and 410 gears. Obviously the gears have to stay in but what is the protocol on the other items???
Old May 28, 2007 | 07:32 AM
mustang_lurkers's Avatar
I don't know. Do you think they will be able to tell that you ruined your second gear because of the way you abused it?
Old May 28, 2007 | 10:49 AM
ford4v429's Avatar
legacy Tms Member
heheh- I'm in the same boat here-powershifting apparently damaged 2nd synchro...guys at work are giving me a hard time about it- say I should take it in under warranty, but I say if I abused it/tore it up, I should fix it, not Ford...then they argue'why did it ever grind the first time?' as maybe the synchro was not quite right when new...but my guess is its just a little small for the abuse, 3rd barks just fine, no issues...who knows...I'm thinking of getting a spare from newtakeoffs.com for 800 bucks, then have this one beefed up a bit.
In the short term I added royal purple ATF, gotta say that stuff does seem to help- third is silky smooth, 2nd a *little* better, but still, not great...I can shift up to about 5k, but above that, the shifter either feels like it hits a solid stop(then goes right in at <5k) or grinds slightly just as it engages...whatever next tranny or fix is, definitely going with the royal purple ATF from now on- I'm sold...perhaps if I had put it in sooner the problem never would have came up at all...
Old Jul 11, 2008 | 11:15 AM
07ShelbyWanter's Avatar
my 2nd gear synchro is grinding into gear too. happened after a good 1st thru 3rd burn out. oh well. i took it in, complete w/ CAI, tune, and axlebacks, and they said it was a TSB for the 1-2 shift synchro. they didn't have any qualms (so far, knock on wood) and scheduled me for next week.
Old Jul 11, 2008 | 11:55 AM
05GT-O.C.D.'s Avatar
I lust for a M24
Can you post a link for exactly what you put in. I assume there's only one Royal Purple ATF formula?
Old Jul 11, 2008 | 12:19 PM
Ranger's Avatar
This may not be relevant to your situation but there is a TSB for some 05's regarding Grinding/Growling in the tranny. I had the problem around 6K
Old Jul 11, 2008 | 11:07 PM
GottaHaveIt's Avatar
set tune to factory I'd take off CAI & put stock back 10 min tops right just incase they refash ECM anr record stategy number so when you get it back read stategy if not match don't touch or try to upload a tune.
Old Jul 21, 2008 | 09:24 PM
ford4v429's Avatar
legacy Tms Member
John, they call it 'synchromax ATF' went up to summit and picked it up...you going back to '42 this summer?
Old Jul 21, 2008 | 09:28 PM
I lust for a M24
I blew over 1/2 tank of gas just going up and out there last time. I don't know that I can afford it right now. I'm itching to go, hopefully I'll be able to. With the tight budget, I can't justify burning money right now.
Edit: With the tight budget, I can't justify burning money to my wife right now.
Rando
Aug 25, 2021 11:12 AM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
