coolant level low
coolant level low
I popped the hood of my mustang this afternoon and noticed the coolant level was very low even though I had just had it changed. My car doesn't seem to be rising in temperature and the low coolant light is not on. I see no leaks in the driveway and so I also tried to video my exhaust while revving it a bit and no white smoke. Is it bad that this continues and if it is what can I do and what do you think is causing this problem. Thanks in advance!
Jiffylube.. but when they changed it it was full at first, and now its like half of the whole coolant container. And right now I actually notice my car temperature going up and down by just a lil bit.
Probably didnt burp out all the air (if they even changed it... jiffy lube has a horrible rep)
The problem is that the air wasn't removed from the system. I don't know if the '06 requires an airlift system or not (the '11 and up 5.0 does at minimum) to prevent air pockets. The 4.6 in my '97 can be a bit of pain to get the air out, I doubt it got easier with later cars. In any case the Jiffy lube help were probably in a jiffy to move cars through and didn't take the time to do it.
The good news is generally speaking engines purge the air on their own. The coolant from the recovery tank fills the air pockets and the air goes to the recovery tank. Hence a low coolant level. Top it off with 50/50 and watch it. Given what you're saying on the dramatic change in level it's probably done purging the air.
The temp gauge will go up and down as the cooling fan comes on and goes off. Some times with speed changes (air flow). That's normal.
Jiffy lube has low cost labor, I'll let the reader figure out what that means wrt the quality of the work.
Thanks a lot for the helpful info.. so ill just top it up with water while the engine is cold correct? The coolant they put was yellow btw. I dunno what type that is, but just some extra info to clarify if topping it off with water is fine.
I would call and ask. Hopefully they used an extended life coolant.
In my old F150 I have had to have the radiator repaired twice over the years. I've always just used water out of the hose. I will say there is quite a bit of calcium deposits inside the core before they boil it out. Which means there is surely calcium in the cooling passages of the engine.
So distilled probably is the best way to go for longevity of the cooling passages.
I'm on well water that does have some calcium in it. Will leave bad water spots when I wash the car if I don't dry immediately.
And don't use the red/orange coolant (DexCool)
Just to be safe, check your oil for any cloudiness. I'm sure it is just that Jiffy Lube didn't bleed the system but you should make sure the anti-freeze isn't escaping into the oil system via a failing head gasket, or on certain vehicles the intake gasket-- but I can't remember if that applies on these cars. I had a failing intake gasket on my 96 Monte Carlo I used to have and started seeing little milky wisps on the dip stick. Then before I knew it, the oil turned to chocolate soft-serve ice cream. Had to pay a shop $500 to change the gasket and clean out the entire oil system and I was **** lucky I didn't ruin my motor.
Last edited by Cavero; Jul 6, 2013 at 08:06 AM. Reason: ref'd straight anti-freeze and monte example
