Charging System???
I have a '05 Mustang, the battery keeps draining when the car is off, I have replaced the alternator, the battery and still no fix, I also rewired the charging system when I relocated the battery to the trunk, this problem started before this, I have an amplifier, but it works off the signal of the cd player not a shaker either, the battery drained from 12 to 6 volts in 24hrs. On a side note, my horn stopped working a while back, and keylessentry for the trunk doesn't work either. Something has to be using voltage when the car is not in use, I just can't figure it out.
Get yourself a meter with a clamp-on current probe. Attach the probe to observe the drain on the battery with the car off, then start pulling fuses one at a time until you find the circuit that’s pulling the most amps. The computer and clock will use a tiny amount btw, but not enough to kill your battery. I’d recommend to start with the stereo equipment or anything else not factory.
I started doing that last night, I have a fluke, only bad thing it doesn't meter after the decimal place, but I pulled some fuses and relays, I pulled the relay for the horn and defroster, and pulled fuses for the pass. window motor, radio, trunklid release and I disconnected the amp too. Something I noticed last night when I pushed the button for the window the lights would dim slightly and a clicking noise would come from passenger side door. The car started without problems this morning, so hope
fully I'm on to something. |
Are we talking it drains after being parked for 2 weeks or it drains after being parked for a day?
If after 2 weeks, this is a common problem. The car is not "off" when the car is "off". Security system, NAV unit, Radio, etc may be the cause since they are drawing some current when the car is parked (not sure if anyone ever really figured it out). During the first year, my car battery was draining if I parked it for about 2 weeks or so. Since then, if I know my car isn't going to be used on a given week, I hook it up to a trickle charger. Many threads on the issue. Here are a few: https://themustangsource.com/f739/ba...roblem-479609/ https://themustangsource.com/f739/dead-battery-427426/ https://themustangsource.com/f739/de...lready-446863/ |
It's over night, I know some ford's can draw about 300-400 milliamps while the car is off, if it was over a few weeks I wouldn't be on here, but not when this problem has cost an alternator and 2 batteries.
Originally Posted by obxdude018
(Post 6014915)
Edit-The problem came after my header install so I think I might have knocked something loose during the install. |
| All times are GMT -6. The time now is 03:59 AM. |
