-   Repair and Service Help (https://themustangsource.com/forums/f739/)
-   -   Automatic making terrible noise when pulling up hill (https://themustangsource.com/forums/f739/automatic-making-terrible-noise-when-pulling-up-hill-442735/)
stangmomasc Oct 30, 2006 07:28 AM
Ok....about a week ago my Auto GT started making a terrible klunking noise like metal banging on metal going up the very steep grad on the mountain I live on....everyday it has gotten worse......it sounds like the rear end is falling out......anyone else had this or heard of it,.......it goes to the dealer today and I need to know if anyone else has had this problem....it only has 2300 miles on it.
sodaman Oct 30, 2006 07:46 AM
who knows, probably the rear end tsb, clutch paks probably broke or something. get it in to the dealer
mabullitt Nov 12, 2006 03:37 PM
I have a problem that sounds like it could be related: In forward or reverse, starting slowly from stop (usually under 1,000 rpm) I can feel and hear a grinding and vibration from the rear end. It happens most noticeably under load, like starting from stop, going up a hill, with the wheel turned. I can’t tell if is from the transmission, the rear axle assembly or the brakes. If the car had limited slip I would guess that it was the clutch pack.
