2005-2007 vs 2008 4.6 3V Spark Plugs?
Brisk !
The circled area is the area that can break on the factory 3V plug. The brisk plug in this area is not a separate piece and not prone to the breakage.
Its not a common occurence for the factory plug to break but the factory design does allow for that possibility and if you dont have the special tool required to get the plug out from Ford you're going to be pulling the cylinder heads off to fix it.
I'd be more concerned about anti-sieze dripping or contaminating the electrodes on the spark plug. I haven't heard of any long-term results using the Brisk plugs. I am just going to keep the stock plugs for now and deal with it later and wait for the OEM to release updated 1-piece spark plugs.
The bottom part corrodes badly and can fuse to the aluminium cylinder head. You can put anti-seize compound on the thread , but not that portion and when you try to remove plug it breaks there ...
07Foose posted this link to a TSB for the same problem with 05 ford F150. The last page shows where to put the antiseize compound on the bottom portion of the plug.
http://www.fcsdchemicalsandlubricant.../tsb/06152.pdf
Since this is most likely not done at the factory, I was curious if, even using the two piece plug, as long as the AS compound is applied if it would alleviate the problem
Good find
Thanks KC!!!
I'm assuming that with only about 4000 miles on my car I shouldn't have any problems with the ground cap of the plug sticking yet????
If not, as a worse case scenario, does anyone have an idea how much that Rotunda special tool costs?
thanks.
If not, as a worse case scenario, does anyone have an idea how much that Rotunda special tool costs?thanks.
I watched my brothers face as he changed the plugs on his wife's 05 - maybe 25K mileage?
you hear the porcelain crack as it starts to break.......................
thankfully his good racing buddy has had this happen before on a few F150s he's worked on and he was able to get it out...... along with the other THREE that broke.......
what a mess....
called family friend who was in Ford service for a couple decades and just recently retired
they KNOW that this problem can occur in the S197s - so I wouldn't be surprised if they change this for the '10s.....
It looks like Champion has a new one piece plug for the 3V 5.4L engines.
http://www.f150online.com/forums/sho...=318761&page=2
The only problem with the brisk plug, for my car at least, is that it is one step colder than the factory plug.
http://www.briskracing.com/search.php?mode=search
If I had a modified engine, it wouldn't be a problem, but alas, I don't.
I did some research on the Brisk’s plug they make two, 3VR17YS for under 450 HP and 3VR14S a colder plug for over 450 HP Steeda sells them.
I also found this very good video on the problem. It looks at the 5.4 but the heads are the same…chose episode 26.
http://www.flatratetech.com/index.php?categoryid=4
turns out it was the CABLE that plugs into the port - they sent me the wrong one
So he's returning my gauge and a new cable - hope to have it by this weekend! (fingers crossed) I'll get you an update when everything is working via email
What is Warrany in Service Date and What is your Mileage on Vehicle? I can Pull In Service from your Vin if you do not Know. If you do Not want to post you can Email me with Info and I may have a Helpful Answer. clevparts@aol.com
KC
KC
Product Details for OTC303-1203
SPARK PLUG REMOVAL TOOL
OTC303-1203
OTC
SPARK PLUG REMOVAL TOOLOTC303-1203
OTC
Application:
2004-2008 F-150 5.4L 3 Valve
2004-2008 F-Super Duty 5.4L 3 Valve
2004-2008 Expedition 5.4L 3 Valve
2004-2008 Navigator 5.4L 3 Valve
2006-2008 Mark LT Refer to TSB for complete procedure.
Here is the Tool!
