2005 to 2007 Mustang Dash Wiring Swap Issues!
Hey guys, new to forum, new to S197, not new to cars. During my swap from nasty and abused 2005 gt manual trans, to cherry 2006 gt auto, everything matched up the same pretty much, however there is a connector basically right at knees of driver, that is not on the 2005. Trying to verify what that is for and if I need to tap into the 2005's harness etc. Any help.would be amazing!
UPDATED TITLE. Op Had 2007 Dash Harness not 2006! Kc Admin https://cimg5.ibsrv.net/gimg/themust...8b6dd852a6.jpg https://cimg6.ibsrv.net/gimg/themust...c89bcb6ca8.jpg https://cimg7.ibsrv.net/gimg/themust...b5a7921bdd.jpg |
16 Attachment(s)
@Comer24
These Maybe Helpful! The C-307 Looks Like Your Connector. Is it Possible it is Console Shifter Plug??? KC |
(Post 7082753)
@Comer24
:nice:
Have Fun! Kc |
Same connector
Originally Posted by Comer24
(Post 7082755)
very helpful thank you! I believe you are right. I'm not trying to heat my seats, only thing i might need is NSS wiring tap in the event this thing needs a closed position to start the car. You are amazing for these ! Thanks again!
https://cimg1.ibsrv.net/gimg/themust...9e1170ec4e.jpg https://cimg6.ibsrv.net/gimg/themust...4d92bdc345.jpg wiring colors, but this one runs up to my knees right below steering column. .. |
Is There a Sub harness on Your Pedal Assembly???
Also What Connector is That With the Thick Wiring Off to the Left??? Is It For RCM?? Pics Need To Be Pulled Back For Better Reference As To Locate in Scheme of Things. Also Not Clear On What Exactly You Did?? Took Dash & Wiring Out of 05 Stick & Replaced With Used 2006 Auto Dash & Wiring or Was Trans Swapped?? Not Quite Clear on That. Also Be Advised Wiring Harnesses Do Often Have Extra Plugs Unused When a Certain Option in Not on Car. KC |
05 cont
(Post 7082767)
Also What Connector is That With the Thick Wiring Off to the Left??? Is It For RCM?? Pics Need To Be Pulled Back For Better Reference As To Locate in Scheme of Things. Also Not Clear On What Exactly You Did?? Took Dash & Wiring Out of 05 Stick & Replaced With Used 2006 Auto Dash & Wiring or Was Trans Swapped?? Not Quite Clear on That. Also Be Advised Wiring Harnesses Do Often Have Extra Plugs Unused When a Certain Option in Not on Car. KC https://cimg1.ibsrv.net/gimg/themust...350286e260.jpg |
Ok, I Had a Feeling about The Wiring That it Maybe Newer Than You Thought! Your Picture Bears That Out. The 7R33 Prefix Indicates a Part Produced in 2007. See Floor Styrofoam and Wiring Harness Tag. Also Some 08 Parts Would Be 7R Prefix as Well. The 08's Had The Ambient Console Lighting Which May Come into Play! I Had Already Started Down that Path!
Another Shot of Same Harness As Lying But Of Transmission Hump Would be Helpful! Stand By. I Don't Suppose You Have Donor Cars Vin??? Tell Me If Your New Dash Has The Tabs On the Bottom Center Of Dash On Both Sides. As Per Center of Glove Box Bottom. as Shown on these Pics. I Wish the First Pic Was Not Blurred Looks Like Your Plug. https://themustangsource.com/forums/...4/#post7070406 KC |
My cell is 808 304 3880. If easier to communicate via text. I've got a couple other questions as well lol. I'll get the Vin of the 06 once I get back to house.
Get Vin and We Can Proceed From There!
Kc |
Vin
Here's pics of Vin and console wiring.
https://cimg3.ibsrv.net/gimg/themust...49f7cfb650.jpg https://cimg2.ibsrv.net/gimg/themust...20f4c016bd.jpg https://cimg6.ibsrv.net/gimg/themust...821eade802.jpg |
16 Attachment(s)
I Believe You Have a 2007 Harness, Which is a One Year Wonder in Regards To How Aux Input New for 07 Was Wired In.
Check Color Codes! On Your Newer Harness Plug To Match. Your Car Would Not Have Aux Input. Update, C-219 Would Be Female Counterpart to Your Pictured Male Plug You Posted. See if Any Wiring Left in 07 Console. Note Typo on Console PDF. Should Say C-219 Yep It's an 07 By Vin. Even 08 is Different Even More in Console Area. KC |
Thread With Pats Info!
As Promised Via Phone call! A Great Great Fellow Gearhead Btw! https://themustangsource.com/forums/...0/#post7073815 , Maybe Helpful Links https://themustangsource.com/forums/...-newer-549894/ , https://themustangsource.com/forums/...5/#post7074372 KC |
Long Story Short Op Has 05 Mustang and Bought Parts Car Seller Said Was 06. Op Had Installed Dash & Harness Not Knowing it Was 07. 07's Due To Changes Such as Aux Input For Radio Had Some Wiring Pin Differences and Would Have Required a Lot of Back Tracking. Car Would Not Start With 07 Harness. Op Reinstalled 05 Harness and Car Started First Time. 07 Car Was Purchased For Mint Interior for 05 Car!
Note to Viewers, Bottom Line Be Advised When Using a Used Wiring Harness That You Need To Stick with Same Year Like Equipped Car if Possible. This Was Under Dash Harness Only. I Enjoyed Helping Him Out With the Project! One of Our Fine Military People Serving in Hawaii and a New Friend! KC |
I Hope Conversion Has Worked Out!
I Know Helping On This Thread Gave Me a Lot of Answers For Our Latest Thread on Member Putting 07 Engine & Trans in 05! https://themustangsource.com/forums/...ispreloading=1 20 Years on With the S-197 and I Know I'm Still Learning. In Fact Learned a Lot in The Last two years Being Back about Retrofits. It Was My Specialty Back in the Day For Upgrades and Now I'm Learning about Adapting To Keep These Cars Going With Cost Effective Used Parts Options! All Good! KC |
| All times are GMT -6. The time now is 12:59 AM. |
