Good Alignment Shop in Huntsville
Looking for a good alignment shop here in huntsville. I just did a pretty extensive suspension swap on my 2011 Roush and need to get aligned before i start eating tires.
legacy Tms Member
legacy Tms Member
everything is near texas ...i kinda thought it was but still had to look it up .. huntsville texas was named after huntsville bama .....and anyway i cant imagine any one alignment shop would be any better than any other around .. most should all use the same equipment ..
i figured most all of them used the same equipment, but only as good as the tech using the equipment.
Didn't know if anyone had any experience with any shop that seemed to really know what they are talking about.
legacy Tms Member
log on to( huntsvillecarscene.com) and ask the same question .. more members from the immediate area and you most likely will get a recommendation or two ....
I've used NTB once and stood back there and watched them. Other time I did it myself. I don't think I would really recommend them since they told me I didn't have camber/caster adjustments when they are on top of the strut towers, they were just looking under the car.
Not in Huntsville (Decatur), but these guys are pretty darn good. Will align to your specs, too.
http://cagletirecenter.com/decatur-a...-alignment.htm
In the past, Big 10 on Wall Triana in Madison did all my alignments. Pep Boys bought them out, but Kevin is still there. I installed the Eibach suspension kit on mine along with adj panhard bar and he did a great job. He will work with you on your camber preferences (if you installed camber adjustment parts).
ssjbuu
8/28/15 08:55 AM
