Air Filter
Anyone ever find out what model number K&N filter can replace the factory paper filter?
K&N Part No. 33-2298 (for 4.6L)
thanks
sorry my bad, i need the model number for the Bullitt filter that is the GT panel filter
Theoretically K&N part number RE-0870 should fit. When I measured stock filter the dimensions I found were:
flange - 4 inches Height - 10 inches Base outside diameter - 6 inches Top outside diameter - 5 inches. According to the K&N site, the dimensions on the RE-0870 are: Base Outside Diameter: 6 in (152 mm) Flange Inside Diameter: 4 in (102 mm) Flange Length: 1.75 in (44 mm) Flange Type: Centered Height: 9 in (229 mm) Top Outside Diameter: 4.625 in (117 mm) http://www.knfilters.com/search/prod...x?Prod=RE-0870 Its not an exact fit but should be close. I contacted K&N a couple of weeks ago about having them build a custom filter. I basically got told to just find a universal filter that fits. Oh well... |
there isn't an exact fit filter but there is one you can make a slight modification on.
Got to IMBOC and do a search |
