"Tire Pressure Sensor Fault" Indication
Working on the CalStang out in the shop. We now have it up on the jackstands and prepping him for the upcoming winter storage. Cleaning, waxing, leather treatment, detailing everything on the inside, outside and even the underside of it too, because we do show it. Hell is in the details!!
Noticed a "Tire Pressure Sensor Fault" indicated on the dash data warning system. All tires are set at proper pressures. Wondering if maybe the tire's sensor batteries are finally giving up the ghost on this 2007 Mustang's wheels? Spare does not have one does it? Don't know what the expected battery life is on these? Have that heard about five years is the average? Anyone else been down this road? If so have you replaced them yet? Just wonder what that costs to purchase four new units that connect inside the wheel with the metal bands? Any info here on this one? :dunno: "RC" |
some discussion here just a few days ago:
https://themustangsource.com/f726/da...4/#post6187351 |
Spare does not contain a tpms sensor. And I would also recommend changing to a valve stem type sensor because the batteries are easy to change in them. Valve stem sensors can train with the tpms system just like band sensors.
Originally Posted by texastboneking
(Post 6189155)
Originally Posted by Doogie
(Post 6189177)
I did not believe it is that easy as the sensors use a specific frequency... for example, the stem style sensors used on the '10+ will not work on the '07-'09s. Unless of course, you have some additional information on which stem style would work on a car that came with a band style sensor??
Thanks TMS Gang!
Thanks for all of this TPMS input gang! Sounds like we've have just joined this sensor club? Thinking the stem type units might be the good ticket for replacements if they will work on our 2007? Any Ford service people here who know? This problem can be addressed this coming spring when our CalStang comes back out of winter storage. Thanks again.."RC"
If I can get someone with an 05 to come by the dealership I can get some sensors and try it out. Need someone to come by though.
(Post 6189363)
only 07-up have them :) |
RC, when I replaced my wheels a couple of years ago I purchased the kit from American Muscle for $150. It was the best price I found at the time. It included OEM Ford sensors, metal bands and a Ford reset tool. As I understand it the 07-09 sensors work in conjunction with the ABS system and determine speed differential between wheels on the same axle. For example, both fronts could be low by 15 psi and the system would not trigger a fault because they would be turning the same speed. This is also why it won't tell you which tire is low. The newer system actually measures individual tire pressure. I don't think the two systems are compatible, but I could be wrong. It wouldn't be the first time,lol.
The sensors today 2000 and up communicate with the tpms module and not the abs system. Ford for some reason won't allow the system to tell you which tire is low. When you train the tires you train them in a specific order so the module knows the location of the tires. Now why Ford won't let it display which tire it is Idk. |
Like I said I could be wrong but I did quite a bit of research when I bought my sensors and that's the information I found. It's been a couple of years ago though. The reason you train the sensor starting with the left front is so the system will know which axle each one is on. 1 and 2 are front axle and 3 and 4 are rear.
