Thanks a lot, my wife is always laughing at me cause on weekends I'm in garage with my 11yr old son cleaning everything.
Fuel gauge is Auto Meter. |
Does it have a special fitting on it? Do you have a part number handy for it by chance?
Sean
Originally Posted by MSVR3
(Post 6069133)
How did you guys use the 3/8" spring lock tool on the fuel line to get it off? Mine does not seem to want to get in the opening properly because there is a part of the frame in the way.
This is the spring lock set I have: http://www.princessauto.com/workshop...nnect-tool-set Is this the same thing to use on the bottom coupler. The fuel rail side was eay as there is nothing in the way, but that bottom one just doesn't want to budge. Sean |
Originally Posted by SeanD
(Post 6110394)
This is the spring lock set I have: http://www.princessauto.com/workshop...nnect-tool-set Is this the same thing to use on the bottom coupler. The fuel rail side was eay as there is nothing in the way, but that bottom one just doesn't want to budge. Sean Scott |
Hey Scott,
Are they these ones? http://www.princessauto.com/workshop...disconnect-set If so, I will go get it in the morning. Thanks, Sean |
(Post 6110538)
Hey Scott,
Are they these ones? http://www.princessauto.com/workshop...disconnect-set If so, I will go get it in the morning. Thanks, Sean Sxott |
