Passenger Window
I recently had my passenger door glass replaced. When I washed it, I noticed water seeping inside the glass. I felt around the top of the glass and I see that it has a gap between the top seal and the glass. The driver side seats higher. It appears the install was not done correctly or it needs to be adjusted. I have read about de-initializing and then initializing. I would rather not disconnect the battery to perform this. Read about getting an error message. Can an adjustment be made to correct this? I would appriciate help with this. Also please don't suggest taking it in to the glass install to have them correct the problem. I would rather not let them work on my baby anymore. Thanks so much for any suggestions and help. Joe
Originally Posted by GTMUSTANGCS
(Post 6440230)
think you just hold the switch up 3 sec after it bottoms out, and down 3 sec...its in the manual I know
(Post 6441186)
