-   2007-2009 Shelby GT500 (https://themustangsource.com/forums/f727/)
-   -   Aftermarket Rear Spoiler On a 2007 Shelby GT (https://themustangsource.com/forums/f727/aftermarket-rear-spoiler-2007-shelby-gt-544589/)
MDMachiavelli 9/12/17 07:38 PM
Is it possible to get a rear spoiler off of the trunk without damaging the paint?
I'm not really sure how they are secured so I just don't know.
Thanks.
dly 9/13/17 04:17 AM
Remove the bolts that hold them on and then use fishing line to cut though the glue and rubber gasket. Clean the area with alcohol.
MDMachiavelli 9/13/17 07:55 AM
So in other words there are holes drilled into the trunk lid.......
2k7gtcs 9/13/17 07:57 PM
Here's the thing. The 2007 Shelby GT had no spoilers so I'm assuming you have one that somebody added a spoiler to and you want to return it back to original?
If they drilled holes to install an aftermarket spoiler, then most aftermarket spoilers use the existing holes. Of course a SGT has no holes but they did have a stock trunk lid which had provisions for holes in the underside of the trunk lid. If it's drilled you can tell on the underside as those screw heads a visible. So I guess check that first.
MDMachiavelli 9/14/17 05:57 AM
Yeah its not one I own but one I'm looking to buy online.
I will get them to take pictures so I can see.
Thanks.
