What other parts should I be concerned about if my pinion bearing went bad?
I have a 2013 Mustang 3.7L and Ford just replaced my pinion bearing among a few other things. I will have more details later today when I pick the car up. The dealership said they found metal shavings in the differential.
I've driven a few hundred miles on this bad pinion. My back tires wobbled back and forth and there was a loud grinding noise
I only have ~20,000 miles remaining on my power train warranty so I want to make sure this is fully resolved. I've never worked with rear differentials before so I'm trying to educate myself. Here's a thread detailing my problems https://themustangsource.com/forums/...ar-axle-538888 |
Originally Posted by Rando
(Post 6948572)
Originally Posted by TheReaper
(Post 6948602)
Drive your car and enjoy it, stop worrying about it breaking down.
Here's what Ford replaced on my car |
How much did it cost you to get all of this done?
Originally Posted by firstang001
(Post 6949488)
It's not very likely the ring gear, side gears, and spider gears would be damaged from some metal shavings. They are pretty hard gears. What you might be concerned about is the limited slip differential and the clutch packs in there. It looks like the tech just inspected the pinion and carrier bearings, and didn't look at anything else. Common practice though...if it's not broke or being complained about, DON'T fix it. I honestly wouldn't be too worried about it though.
Small particles
https://cimg1.ibsrv.net/gimg/themust...1505ec3f96.png
I was checking my oil separator the other day JLT oil separator, Ford performance valve covers, PA Performance Alternator, upgraded wiring kit for alternator, have a Pacer Off-road H-pipe(catless), MBRP axle back muffler delete. I use motocraft 5W-20 full synthetic with the FL-820s motocraft oil filter change every 2,500 miles at 115k miles it’s a 2007 4.6. I have cams and fuel upgrades but I don’t want to get in big rush with seeing this like this. Any help or suggestions on where to start? I also have a Bama Rev-x tuner and had a popcorn tune for about 1 week and half and took off and car still pops. Like that tune is still on I’ve tried reflashing but it just doesn’t seem to work. |
those particles are in the oil catch can?
that's a new one for me . . . they must have come from the crank-case somewhere, and I am amazed that they would be carried out by the vented gasses so they can be caught in the catch can I think it means two things and sorry I can't be more specific: 1) there is something grinding itself up in the lower part of the engine 2) you have a lot of blow-by, maybe bad rings? how much oil are you collecting in the catch can? what is a "popcorn tune"? when my engine sounds like popcorn, that is usually a very bad thing -- usually the sound of bad pinging, which could be causing the damage EDIT/PS -- since your question is completely different from the original topic of this thread, you might want to start a new one with a clear title to get a better response |
Originally Posted by Bert
(Post 7063924)
that's a new one for me . . . they must have come from the crank-case somewhere, and I am amazed that they would be carried out by the vented gasses so they can be caught in the catch can I think it means two things and sorry I can't be more specific: 1) there is something grinding itself up in the lower part of the engine 2) you have a lot of blow-by, maybe bad rings? how much oil are you collecting in the catch can? what is a "popcorn tune"? when my engine sounds like popcorn, that is usually a very bad thing -- usually the sound of bad pinging, which could be causing the damage |
