What all this hopping around?
Old 8/28/10, 11:27 AM
AK 5.0's Avatar
Could this the 19" wheels be causing this or the brembo package?
Seems like everyone with them has wheel hop. Just a guess.
Old 8/28/10, 12:56 PM
FivePointO's Avatar
I don't have any wheel hop. It has been nothing but hot since I got my car, so maybe weather could be a factor ( tire temp )? If anything, from a dig race I get a lot of wheel spin, but no hop. I still want LCAs for better grip and corner carving.
Old 8/28/10, 05:10 PM
falhulk's Avatar
I have the bebo 19's and 3.73's and have not had the hop. Does this happen with the traction control on, off, or in sport mode?
Old 8/28/10, 07:00 PM
montreal ponies's Avatar
Originally Posted by crescent_wrench
Lower your car and hop goes away....at least for me.
Same here with lowered car, lots of hard launches 1st-2nd and no wheel hop at all. But i'm going to do a shocks and struts swap very soon as recommended by Sam Strano.
Old 8/28/10, 07:04 PM
postalworker's Avatar
I have the 19's, 3.73, and manual- have not had a problem even once, only 1900 mi.
Still at stock height, for now..........
Old 8/28/10, 10:58 PM
InsidiousGT's Avatar
Try power shifting, it will happen.
I'm guessing all the people who say they don't have hop aren't going to the drag strip.
Old 8/29/10, 01:19 AM
brycerichert's Avatar
I've been burying mine quite a bit lately and don't have wheel hop.
Old 8/29/10, 03:25 AM
Ducky's Avatar
You're comparing apples to oranges here. Your cobra has an IRS (unless you converted it) and your Mach 1 has a 4 link suspension on the solid rear axle. Since 2005, the Mustang has had a 3 link rear suspension, 2 lowers and 1 upper on the pumpkin. Great for handling because a 4 link will bind in heavy cornering, not so good for wheel hop. As far as wheel hop goes, 4 link > 3 link > IRS. Replace your bushings and LCA's, then learn how to turn, and you will love your mustang.
Old 8/29/10, 05:17 PM
falhulk's Avatar
That explains it. I dont power shift mine.
Old 8/29/10, 08:12 PM
It has been, and still no problem...
However, it will most likely never see the track...
Old 8/30/10, 05:26 AM
pony racer's Avatar
ok for all the NAA sayers that dont have wheel hop..
next time you go out..
drop the clutch with traction control on either mode.. like your doing a burnout,..
trust me.. you will have wheel hop..
i shut the t/c completley off. hit second hard enough and get hop even in third..
need to put LCA's with poly bushings on to fix, the LCA factory bushings are very soft..
Old 8/30/10, 07:53 AM
born2run74's Avatar
So does that mean it is very hard to do a burnout without wheel hop?
Old 8/30/10, 09:04 AM
Freshmeat's Avatar
Get the UMI Performance anti-hop kit. It's LCAs and relocation brackets (if you're lowered and/or want a better launch) and made a huge improvement in my handling off the line and in the curves. I'm 10x more confident in how the car will handle when I do some things.
If you just want the control arms, their quality is great and the price is irresistible.
Old 8/30/10, 12:05 PM
falhulk's Avatar
What rpm are you dumping the clutch? I have not gone beyond 4k and do not powershift at all.
Old 8/30/10, 01:57 PM
SD6
SD6's Avatar
Finally experienced wheel hop last night. Was with a buddy and gunned it up slightly uphill on a bridge, hopped around 2nd to 3rd if I can recall.
Looks like if the solution is to get it lowered = that might happen sooner than I had planned!
Old 8/30/10, 03:21 PM
6k ish
Old 8/30/10, 04:09 PM
AK 5.0's Avatar
Dumping the clutch at 6k seems kinda counter productive to me?? At that point I do not believe you are going to get a good launch (over power the tires) unless they are slicks.
Old 8/30/10, 08:44 PM
I meant between shifts
Old 8/31/10, 05:53 AM
wouldn't just getting lca relocation brackets fix this problem?
Old 8/31/10, 09:49 AM
  #40
According to some, just LCAs will do it. I plan on getting the Steeda ones this week, so I will let everyone know.
Quick Reply: What all this hopping around?
