The UPS man showed up!!!!!!!!!
#43
The UPS guy dropped off my Roush fascia yesterday! It looks good! They shipped my splitters separately, but just checked and they will most likely be delivered today. Merry Christmas me! My setup will be pretty similar to yours.
Now if santa would just bring the roush exhaust axle-backs
Hey Chip, how difficult is it to install this fascia and fog light kit? I'm thinking about doing it myself. I've never done something like this before but it looks okay. What do you think? Also, how did you run your wiring?
#45
Thanks for all the great compliments! Here's a few more pictures with the latest piece that showed up (My Little Pony) grill emblem!!!
Attachment 81959
Attachment 81961
Attachment 81959
Attachment 81961
Hey you may have missed my question, how difficult was it to install the front bumper cover? I'm thinking of doing it.
#47
The cover was fairly easy to install, a little nerve racking when removing the stock cover. It makes one hell of a noise when you pull it off!!! Sounds like your ripping things apart! I did the whole job myself in about 3 hours! The hardest part for me on the cover was installing the upper and lower grills because of where the screw locations are.
#50
#52
Are you going with the Roush grill if so then your going to hack up the wiring harness from Roush to make it work with the factory fog light switch! If you are pm me and I can explain what you need to do!
#54
Have a question for you both you guys. Had trouble finding a 5.5mm deep socket 1/4 drive anywhere. I did find a standard 5.5mm socket though. Do I really need a deep one?
#55
- Thanks. I'm hoping I don't have problems with the push pins. My local dealer didn't have any extra.
No I'm keeping the OEM grille.
#56
I used a 7/32 6 point socket with a short extension! The push pins come out with a small flat blade screw driver! I just lifted up the push pin enough to get two finger nails under it and pull out, their not that hard! I didn't break any! When you go to pull the stock cover off I started at the wheel well and pulled the cover over the fender well lip. When you get both sides over the lip either have someone hold on to the cover with you or sit on the ground with your legs under the cover and pull straight out! It takes a little bit of effort, you'll know that it came loose when you hear the loud snapping sound! Once both sides are loose the cover will lift off buy pulling out and up!!! Have fun!!!!
Thanks again!
