tpms sensors
Had the TPMS sensor light come on, "TPMS Fault" but went away. It would come and go but hasn't come back for a while now.
Anyone have these issues? of course dealer can't replicate. |
Did you check to see if you had a tire that was low on air?
Originally Posted by GrabberBlue5.0
(Post 6862361)
Originally Posted by azmidget91
(Post 6862363)
Yeah, all tires were correct. It would come on after driving so many miles but would shut off when you restarted the car sometimes.
John |
The TPMS is extremely sensitive to the use of "summer/high performance tires" when used below 40 degrees. I simply reset the system BECAUSE the dealership says "it is normal" even when the pressures are correct which mine have been the last three times on our cars. The dealership always tells me a "fix" is in the works...the last 30 months! YEAH delaerships.
