Tire pressure of 19" premium
TPMS said i had a low tire so i checked the door sill to see the recommended pressure was. It says 32 but three of my tires read 38 and one was 18.
What are all you runnin'
EDIT: I did the readings while tires were cold
On the 18's I like 38/35 F/R.
On the 19 (Shorter Sidewall) I would try 35/32 F/R.
The reason I run a little more pressure at the front is improved turn in. Even the rear was a touch soft at 32 psi. All pressures cold in the morning of course.
9/8/15 10:45 AM
