Those with Brembo package...
Since it seems that the wheel well gap is insane with the 19" wheels, what do most of you plan on doing for suspension work?
I have Eibach 1.5" drop coils sitting at the local Mustang shop waiting for my car to arrive so I can install them.
if you go lower than 1" dont you need more than just coils to get the alignment right?
Having a commute that requires some suspension travel (driving on/off a ferry at all tidal levels), I plan to leave mine alone. Plus, I am an old fart and kind of like the ride the way it is. ;)
EDIT: Oops, sorry, just noticed this thread was directed at Brembo owners. I'm just a wannabe. :) |
My plans as of right now. Still no decided if I want a 1" drop or 1.5".
Eibach 1.5" spring or Steeda Sport Springs (1" drop) Koni SRT-T shocks Steeda Adjustable Panhard bar Steeda Heavy Duty Upper Strut Mounts |
You drop it more than an inch you are going to knock the OEM shocks out of their valve range. You need to also upgrade shocks if you drop it that much.
Dave |
Originally Posted by Dave07997S
(Post 5908569)
Dave |
Originally Posted by Freshmeat
(Post 5908661)
I've talked to lots of local guys who said to just swap the springs, get it aligned, and rock out... this is honestly the first I've heard of needing new shocks and I'm guessing you mean I'd also need new struts up front?
I'm not a corner carver (drag racer, instead), so forgive my ignorance. But, don't the Brembo Pkg GT's turn nearly a full g on the skidpad? That's **** fine handling right out of the box, so why mess with a well-engineered package from the factory?
(Post 5908673)
(Post 5908673)
As good as the Brembo package is, there is definitely a compromise due to ride height and quality. I can assure you a GrandAm/Continental Tire race car is far stiffer than any Brembo equipped car. If I was to do this it would be a full kit or don't lower the car more than maybe .75". Dave |
Originally Posted by Ministang
(Post 5908669)
It mainly depends what your goals are. If it is to improve appearance by lowering the car, then just putting lowering springs on the stock shocks/struts will be ok for some people. If you are concerned about handling and ride quality, then new shocks and struts are an important part of the package when installing lowering springs.
(Post 5908703)
Probably more for aesthatics, so it looks lower. That is what would be my concern is messing with a pretty good package right from the get go. Thats why if you are going to lower the car more than an inch I recommend that you always get a matching shock/strut that will have the right valving for the lower ride height. When you go beyond an inch with OEM shocks the car will get incredibly stiff or it will be bouncy due to the improper valving.
Dave |
Originally Posted by 5PTOHH
(Post 5908482)
Originally Posted by paul e
(Post 5908897)
etc, etc... .
For those not interested in lowering their cars too much, consider the GT500 PP springs/dampeners. I believe they lower the car about 0.5" and you know you'll be getting Ford parts. The ride may be a little stiffer since the spring rate and valving will be for a heavier car, but I would bet it wouldn't be too bad.
see next post
(Post 5908910)
Really? Come on, man.
(Post 5908944)
Seriously... Spell it out for me.. indulge me.
when you go from 18 to 19" rims, and you select a new 19" tire, you select the correctly shorter sidewall, so that overall rolling diameter doesnt change.. Im not being a wiseguy here, but if you have a response other than sarcasm, please answer as to why the 19" rims and tires produce a larger wheel well gap than 18" wheels and tires? Im seriously curious what I am not seeing here.. if the overall rolling diameter of the tire doesnt change, why does the wheel well gap change? |
Considering how crappy the roads around here in New Orleans, the suspension on the new 5.0 is staying stock. I ran C springs on my last Mustang (04 GT) and the ride was just a mess on these roads.
If it ever gets here. |
Originally Posted by ScottH
(Post 5908985)
