-   2010-2014 Mustang (https://themustangsource.com/forums/f726/)
-   -   Sync Bluetooth problems (https://themustangsource.com/forums/f726/sync-bluetooth-problems-548103/)
Eddie333 Nov 24, 2020 05:32 PM
Sync Bluetooth STOPED WORKING!
My Mustangs SYNC Bluetooth system will not work after jump starting another car.
the Radio still works, but the FDIM radio display stoped working. The screen is black.
Can I replace the radio to fix the Sync Bluetooth and display? Or is the SYNC Bluetooth system have a separate module that I don’t know about?
hudson007 Nov 26, 2020 07:00 PM
The SYNC module is located in the glove box area. You might also want to check the fuse box on the right hand side of the passenger foot well. I believe SYNC uses fuse #3 on my 2011, but you should double check the fuse # for your car.
