Surprise, surprise... no spare
Spares will not fit over the rotors... same problem with the GT500s. I don't like it either, but what are you going to do? BTW, the inflator kits sucks... if you use it, and if it works... several have reported that it doesn't, then the TMS sensor have to be replaced. Best thing to do is call roadside assistance and have it towed, or buy another wheel/tire, and purchase a OEM jack kit.
Will the "spare" fit on a track pack rear? If so, and you get a flat front tire, use the spare to replace a rear tire which can then go on the front replacing the flat.
That sounds good but what if the front rotor is the same as the rear too big to get the spare on. well then why wouldnt they fab a rim to work if the inflation kit sucks the big one ? you think it would be cheaper than all the tow bills etc or maybe they bank on not too many of those ?
Another reason I opted out of the brembo package (gotta fix my sig). I want this car to be as fun and worry-free to drive as possible. If I get a flat, I don't want to have to go through the whole process of getting the TPMS replaced, etc etc. Just change the tire, and keep going on my merry way.
You will have to build one from a donut rim and a odd size donut tire to obtain the proper circumference. This issue has been beat to death on other forums. There is no simple solution. As a mentioned, it’ll actually be cheaper to purchase one OEM jack kit and fifth wheel/tire.
Note: I’m referring to the GT500... I’m not sure of the size of the wheels/tires available with the track pack... Maybe donuts are readily available. Just food for thought. I’d hate for someone to install a donut, and then later a new rear end. Nonetheless, a donut will NOT fit the rotors on the front.
A few problems with the inflator kits: 1) It will only work with a small leak, which a can a Fix-A-Flat will be just as good, 2) There are already a few 2010 GT500 owners who have had flats and the inflator formula was already dried up deemed unless, and 3) As previously mentioned, you’ll have to replace the TMS sensor if any substance is injected into the tire.
Possible solution: Ford, or some other manufacture, designs a lightweight donut that fits the rotors and is equivalent to the size of OEM wheels/tires... but I’m not holding my breath.
The space saver spare not being the same height as the original tire is not a major problem so long as it is used as intended, as a TEMPORARY tire that is not used at normal highway speed and for no longer than it takes to get to a place to get a new original size tire or the original repaired. In that short distance and low speed, the clutches in the differential will survive. It would only be a problem if you were to leave the spare on for an extended period of time or use it at higher speed.
I'm sure that cost and weight are a couple of factors in why Ford doesn't include a spare tire in these brembo cars.
It's called "track pack".
Not... "daily driver track pack".
The whole point of forgoing a spare is to save on weight and improve balance.
Having a spare negates both of these.
Sooooo I don't see what the big deal is.
Well, how much gearing would one need just driving around the town?
It's all relative.
But it's part of the 'track pack' package. That's the whole point of it. If you go to a track and go through a course rareeeeeeeely does one ever have a spare in the back. Like I said, it's not daily driver track pack...
It's all relative.
Doughnut wheels must not be all that hard to find or be to expensive. I saw a beater driving around with one on each of its 4 corners!!! I am thinking to myself wondering if the junk yards sell them for cheap.
I'm starting to think its a 'limited slip rear end thing'. My V-6 doesn't come with a spare tire. 18 inch wheels with standard brakes. Comes with a 'Tire Inflation Kit'. Doesn't even offer a spare at extra cost.
18's on GT's 2006 - 2009 had a donut. Don't know about 10's.
