Steeda tunning will increse speed limiter?
Im interested in buying the steeda tunning newest sfx programmer with the tunes for life program. Will they increase the speed limiter to 130 mph or I will have to buy for mpt tunning.
I really like the save and reputable company they are but will love to have the higher governor specially since im in germany with this smaller cars passing me like im standing still at 114. I have a 2013 v6 engine and this will be my first engine mod. |
If I'm not mistaken, most tunes remove the factory speed limiter setting altogether, or most tuners have the ability to turn it off (as well as traction control).
My MPT 93 octane race tune had the top speed limited at 125 mph. It is an opened tune so i can adjust things. I turned off my speed limiter :)
Ask Steeda for an 'opened' tune. You can make adjustments for tire sizes, rear gear ratios, top speed limit and a few other things before you load the tune to your Mustang :)
We can disable the speed limiter.
However, it depends on the car. Its not good on convertibles and the V6 with factory driveshafts. Let me know if I can help assist you with anything further. You can reach me at tim@steeda.com. Best Regards, TJ |
factory driveshafts and speed rated tires???
Originally Posted by Glenn
(Post 6842353)
v6 mustangs have a weak driveshaft that will break if you exceed the factory speed limiter... its why you need to upgrade the driveshaft if you do this. |
If you don't already have one, I'd suggest installing a driveshaft safety loop for added insurance at those higher speeds:
http://www.teamjdm.com/bmr-driveshaf...gt-v6-mustang/ |
I just submitted my tune form on your website so do I have to ask in the notes for this top speed limiter to be removed?
Should I call and tell them or resubmit a tune from on your site? Tired of it stopping at 148 MPH on the autobahn!
Originally Posted by tj@steeda
(Post 6842349)
Originally Posted by JoeMidnight
(Post 6842393)
I think the optional 18" and 19" wheels get you much better tires (I know for sure the performance package does). |
Originally Posted by Joeywhat
(Post 6842413)
Tires should really be priority #1 if you have the 17" wheels, as I believe most/all tires in that size are only rated to 120mph.
I think the optional 18" and 19" wheels get you much better tires (I know for sure the performance package does). I concur. If someone is driving at speeds that exceed the rated tire, they run a very high risk of a blowout.... I've owned and ran z rated tires exceeding 140mph on my 15" rim back in the day on my GSR Integra with Dunlop tires. Its possible to get tires for the 17's |
hmm.... they might have been 16's.... doesn't matter. They were definitely smaller than 17's.
(Post 6842393)
(Post 6842450)
Yes in addition to the shaft, I was wondering about the speed rating on the tires for the 6er's.
Oh I see.. yeah, I don't' know what the tire ratings are for the base tire... I have the performance package... maybe someone can chime in... |
I just received my SCT X4 tuner yesterday from Steeda. You can go in and change the limiter yourself. Factory limits it to 115 and Steeda had it limited to 110. I changed it back to 115 like factory, but will NOT go above that.
I believe the factory two-piece driveshafts on V6 & GT (2010-2014) require the speed limiter set for safety. I, personally, would not mess with top speed, unless moving to a one-piece driveshaft. As stated above, of course improving rubber is a must.
Originally Posted by PJRManagement
(Post 6842555)
Kumho makes W rated [ 168 mph ] tires for 17 in. wheels. The SPT's are listed as a a very high performance summer tire and the 4X's [ all season ] are almost as good, but last longer and don't loose grip when the temps drop below 40* F. Price is quite reasonable too.
