Some new TSB by Ford
8 Attachment(s)
EDITED: Added newer SSM articles
Just some new TSB releases, I had a few issues myself before these were released, so hopefully its gonna help somebody out there..cheers ~~~October 22 SSM 44237 - Effective Oct 14 2013 2010-2013 Mustang - Built On Or Before 10/31/2012 - Outside Door Handle Needs To Be Pulled More Than One Time To Open Door(s) SSM 44226 - Effective Oct 10 2013 Multi Vehicle Line - Front Display Interface Module (FDIM) Display Distortion SSM 44157 - Effective Aug 27 2013 2011-2013 F-150 - 2012-2013 Mustang - No Communication with Power Steering Control Module (PSCM) - Service Tip SSM 44156 - Effective Aug 26 2013 IDS Coil On Plug (COP) Stress Test Application Usage SSM 44144 - Effective Aug 19 2013 Multiple Vehicle Lines - Workshop Manual Update - Audio System - Section 415-00 SSM 32323 - Effective Jul 16 2013 2011 - 2014 MUSTANG 5.0L DRIVERS SIDE EXHAUST SYSTEM 5A213 INTERMEDIATE PIPE RESONATOR MAY APPEAR TO BE DENTED OR DAMAGED SSM 32320 - Effective Jul 12 2013 Multi-Vehicle Gasoline Engine Failure Analysis And Tips - Job Aid Release SSM 32252 - Effective Jun 5 2013 2011-2013 F-150, Expedition, Navigator, F-Super Duty and 2011-2014 Mustang - Multifunction Indicator Lamp (MIL) On Diagnostic Trouble Code (DTC) P1636 TSB 13-05-30 - Effective May 29 2013 2012 Escape, 2012-2013 F150, Explorer, Mustang - Sun Visor Vanity Mirror Door Will Not Close Or Is Loose - Built On Or Before 8/31/2012 SSM 32230 - Effective May 17 2013 2010 - 2014 Mustang Overhead Console Replacement, Equipped With Anti-Theft SSM 32168 - Effective Apr 4 2013 2011 - 2014 MUSTANGS - 5.0L - ENGINE ROUGHNESS/PERCEIVED MISFIRE SSM 32153 - Effective Mar 26 2013 2009-2013 Brake Rotor Protective Soft Cover Removal SSM 32129 - Effective Mar 7 2013 2010-2014 Mustang - Clunk Noise From The Brake Pedal During Brake Release SSM 12055 - Effective Dec 6 2012 2009-2013 Multiple Vehicle Lines - Battery Light Flickers - Stays On - Low Charging SSM 32072 - Effective Jan 31 2013 2005-2014 Mustang Caster/Camber Kits TSB 12-11-12 - Effective Nov 16 2012 2011-2013 mustang Intermittent No Start And/Or Rough Running - Blown Fuse 13 - DTC P0627 SSM 12039 - Effective Nov 13 2012 2007-2013 Mustang Carbon Fiber Limited Slip Differential Normal Noise SSM 12019 - Effective Oct 29 2012 Low Current Switch Failures Due To Improperly Installed Accessories SSM 22512 - Effective Sep 14 2012 LOWER END ENGINE NOISE DIAGNOSTIC AID TSB 12-08-15 - Effective Aug 17 2012 REAR DRIVE AXLE VENT - OIL LEAK TSB 12-08-14 - Effective Aug 16 2012 2011-2012 MUSTANG 5.0L WITH A/C COMPRESSOR DRIVE STRETCHY BELT CONFIGURATION - LIGHT LOWER-END ENGINE KNOCK ~~~~~~~~ October 21 TSB 13-09-22 - Effective Sep 25 2013 SYNC - Various vehicles equipped with SYNC may exhibit concerns related to SYNC features. Refer to the vehicle list to determine applicable vehicle lines and build dates located in the Service Procedure Section along with complete symptom details TSB 13-09-03 - Effective Sep 4 2013 2011-2014 Mustang - Grunt/Creak/Chirp/Squeak Noise From The Front Lower Control Arm Over Bumps TSB 13-08-07 - Effective Aug 20 2013 2012-2013 Multiple Vehicle Line - Intermittent/Inoperative Integrated Keyhead Transmitter (IKT) - Built On 9/1/2011 And Through 12/1/2012 TSB 13-06-15 - Effective Jun 13 2013 2011-2014 Mustang 5.0L - Malfunction Indicator Lamp (MIL) - DTCs P0300-P0308 And/Or P0316 No Drivability Symptoms - Built On Or Before 5/1/2013 TSB 13-05-30 - Effective May 29 2013 2012 Escape, 2012-2013 F150, Explorer, Mustang - Sun Visor Vanity Mirror Door Will Not Close Or Is Loose - Built On Or Before 8/31/2012 TSB 12-11-12 - Effective Nov 16 2012 2011-2013 mustang Intermittent No Start And/Or Rough Running - Blown Fuse 13 - DTC P0627 TSB 12-08-19 - Effective Aug 28 2012 SYNC - VARIOUS FUNCTIONALITY CONCERNS - BUILT ON OR BEFORE 7/1/2012 TSB 12-08-15 - Effective Aug 17 2012 REAR DRIVE AXLE VENT - OIL LEAK TSB 12-08-14 - Effective Aug 16 2012 2011-2012 MUSTANG 5.0L WITH A/C COMPRESSOR DRIVE STRETCHY BELT CONFIGURATION - LIGHT LOWER-END ENGINE KNOCK TSB 12-06-11 - Effective Jun 25 2012 CLUTCH PEDAL SQUEAK OR CREAK NOISE TSB 12-03-01 - Effective Mar 2 2012 2011-2012 F-150 AND 2011-2012 MUSTANG 5.0L - INTERMITTENT METALLIC RATTLE OR SCRATCHING TYPE NOISE - WARM ENGINE AT IDLE TSB 11-07-07 - Effective Jul 1 2011 AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION - NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~ OCTOBER 28 NEW TSBs TSB 14-0134 2013-2014 Expedition, Navigator, F150 And Mustang - 6R80 - Growl Or Buzz Noise While Shifting From Park To Drive TSB 14-0132 Easy Fuel Capless - Concerns With Fuel Nozzle Insertion Or Removal TSB 14-0120 2012-2014 Mustang - 5.0L Engine And Automatic Transmission - Diagnostic Trouble Code (DTC) P219A And/Or P219B TSB 14-0100 2013-2014 Mustang, F-150 - Squawk-Type Noise From Transmission On 5-3 Downshift TSB 14-0076 2011-2014 Expedition/Mustang/F-150/Navigator - Delayed Engagement Park To Forward Or Reverse TSB 14-0046 2011-2014 Mustang - Rear Axle Vent - Oil Leak TSB 14-0037 Global Positioning Satellite Module (GPSM) - Navigation Display Offset Or Incorrect Position Built On Or Before 1/6/2014 SSM 44747 - Effective Oct 1 2014 Various SYNC Equipped Vehicles – Apple iOS 8 and or iPhone 6 Functional Issues: Some customers with SYNC equipped vehicles may experience Bluetooth connectivity issues after upgrading to Apple iOS 8 or using an iPhone 6 with SYNC. This is not a SYNC hardware or software concern. Apple is aware of these concerns and isworking on a fix for multiple Vehicle Manufacturers. In the interim, direct thecustomer to the following Apple support URL: http://support.apple.com/kb/ht6473 SSM 44719 - Effective Sep 17 2014 2010-2014 Mustang - Driver Or Passenger Power Seat Binding - Grinding Or Clicking Noise During Power Seat Operation: Some 2010-2014 Mustang vehicles may exhibit a power seat binding during seat control tilt and or lift adjustment operation. There may also be clicking or grinding noise heard from the seat track area, specifically coming from either the front tilt or rear vertical lift gearboxes. Service inventories have been updatedwith revised seat motor service kits(78617D66), for lower service part replacement procedure. Follow the On-line Workshop Manual (WSM) section 501-10 for diagnosis and replacement procedures. Use available service labor operations. SSM 44584 - Effective Jun 9 2014 2011-2014 Mustang - Oil Life Minder Stays At 100% After 98,000 km (61,000 Miles)- Built On Or Before 3/14/2014 Some 2011-2014 Mustang vehicles built on or before 3/14/2014 may exhibit the Oil Life Minder function not updating below 100% life after the vehicle goes beyond 98,000 km (61,000 miles) on the odometer. Using Integrated Diagnostics System (IDS), reprogram the Instrument Panel Cluster (IPC) to the latest calibration using IDS release 90.04 and higher. Calibration files may also be obtained at www.motorcraft.com. Use available Service Labor times. SSM 44502 - Effective Apr 11 2014 2011–2014 Mustang-Equipped With MT-82 - Transmission-Countershaft Disassembly 2011–2014 Mustang Workshop manual section 308-03A has been updated with more detailed information regarding disassembly of the countershaft. When servicing components on the MT-82 countershaft, up to 18,000 lbs. of force may be necessary to remove fifth and sixth gear. Using heat to ease removal is not recommended as damage to the gear could result. SSM 44454 - Effective Mar 20 2014 Lower End Engine Noise Diagnostic Aid When diagnosing lower-end engine noise and a main or rod bearing concern is suspected, inspecting the oil filter element for bearing metal debris can help to quickly determine if the bearings have failed. For procedure information, refer to the Engine Lower End Noise Diagnostic Job Aid located under the Service Tips tab in PTS. SSM 44352 - Effective Jan 13 2014 2007-2014 Mustang Carbon Fiber Limited Slip Differential Normal Noise 2007-2014 MUSTANG GT500, 2011-14 MUSTANG GT equipped with BREMBO brake package,2010 MUSTANG GT equipped with TRACKPACK, 2008-2009 BULLITT - limited slip differential normal characteristics. These vehicles are equipped with heavy duty/racing type carbon fiber clutches in the limited slip differentials. This type of limited slip differential may exhibit a chatter or moan/groan noise when making sharp low speed turns. These noises are a normal characteristic of the heavy duty/racing type limited slip differential. Note: Driving the vehicle in a tight figure eight pattern 5 times may lessen the complaint for a short period of time. |
Originally Posted by HizliBullet
(Post 6703797)
TSB 11-07-07 - Effective Jul 1 2011 AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION - NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS |
It is available to read online....just enter the tsb number and search. Tells them of issues with after market tunes and piston damage. It is an older tsb.
Wow... I feel lucky that I have not one of these symptoms.... Hmmmmm
1 Attachment(s)
Originally Posted by RubyRedMCA_Beast
(Post 6703850)
I wonder what the details on this one are....
Originally Posted by linelock
(Post 6704030)
It basically tells the tech to look for aftermarket tuning.
Originally Posted by FromZto5
(Post 6704041)
There's a tsb for ford to look for aftermarket tunes? I'm not doubting ya, but who in their right mind would take it to ford for the sole purpose of having them check for a tune and void their warranty????? I can see that happening when they take it in for something else, and in the process ford FINDS the tune....
(Post 6704041)
There's a tsb for ford to look for aftermarket tunes? I'm not doubting ya, but who in their right mind would take it to ford for the sole purpose of having them check for a tune and void their warranty????? I can see that happening when they take it in for something else, and in the process ford FINDS the tune.... |
(Post 6704058)
You been living under a rock? It's a pretty old TSB from the #8 days...like he said, it instructs the tech to look for modifications so that they can void the warranty on a blown #8.
I used to work out of Denton Tx. Talk about living under a rock.... |
Originally Posted by Bucko
(Post 6704179)
Try to show a bit of consideration....not everyone owned an early 5.0 with that problem. They just asked.
I used to work out of Denton Tx. Talk about living under a rock.... Anyone in here ever read a CAI thread, or is that an inconsiderate question to you too? |
I got rid of the squeak noise from my second set of control arms, as soon as I lowered the car with a set of K springs from Ford Racing, now the suspension doesn`t go up and down so much over the speed bumps and the noise is gone, hehe
have most of those.
(Post 6704248)
And I just confirmed what the TSB was about. I don't own a 5.0 either, so that's irrelevant. He was also just posting in a thread and didn't know that AM had a forum discount. For someone with so many posts, I find both of those surprising.
(Post 6704058)
(Post 6704248)
And I just confirmed what the TSB was about. I don't own a 5.0 either, so that's irrelevant. He was also just posting in a thread and didn't know that AM had a forum discount. For someone with so many posts, I find both of those surprising. Anyone in here ever read a CAI thread, or is that an inconsiderate question to you too?
Regarding your first quote, I'm familiar with the #8 tho I never had the issue. The comment/question I had was in specific context to the verbiage he put on that tsb. It made no mention to the #8, so no I'm not familiar with the exact tsb. It just seemed odd that there's a tsb to LOOK for a tune... Or so it seemed on the verbiage. But now I understand that if the customer takes it in for some other issues, the tech will be instructed to find the tune. Ok, makes sense. As to your second quote, I KNOW there's a forum discount for AM, but I never bought from them before so if they never gave out the code except in private, how the heck will I know what the code actually is??? |
(Post 6704592)
Whoa whoa whoa man. We've had some good posts/exchanges before, so I'd appreciate the tone down... |
(Post 6704610)
PM'd.
Could someone clarify what's the difference between an SSM and TSB. Is an SSM an issue that hasn't become a TSB yet?
Also, is there anywhere online to see these SSMs? I've got several of these and would love to go into the dealer with printouts in hand. |
Originally Posted by AzPete
(Post 6703903)
Originally Posted by elkk
(Post 6704894)
Where would I go to look up TSB's by number? |
(Post 6704952)
I think he meant Google. They should be pretty easy to find.
