Rear only lowering spring kit?
55D spring kit Http://www.brembo50.com
After that just replace the panhard bar, lower the car to the ground, measure the rear tire fit to see how it needs to be adjusted. If you're skinny you can actually crawl under and adjust the panhard bar without jacking the car back up. Alternatively, if you're not so skinny but have a level garage and sloped driveway like I do you can park with the back tires just inside the garage so when you lower the car there is enough room to crawl under the back and adjust the panhard. Otherwise you'll have to jack it back up to adjust it, then lower it to measure the change to make sure it's right.
Thanks!
14BlackGT
23
9/11/15 04:57 AM
