Notices
Sponsored By:
Sponsored By:
OBD2 port and boost
Old 5/5/14, 04:56 PM
rmurer's Avatar
OBD2 port and boost
Can the OBD2 port give a boost read out? I'm looking at using the Aeroforce interceptor as a gauge and i feel like im getting mixed input from searching google.
Old 5/5/14, 06:25 PM
det97's Avatar
Based on internet and owners manual yes.
Old 5/5/14, 09:27 PM
Owners manual says obd II port has boost data? I don't think so.
Op, I know this topic was from your other thread, but I have conversed with a few vendors about the aeroforce, also a couple other sources. 5.0 GTs don't give manifold pressure (ie boost) readouts.
Old 5/5/14, 11:10 PM
db2797's Avatar
You need to install this sensor if you want to measure boost:
http://www.americanmuscle.com/aerofo...nsor-9612.html
Old 5/6/14, 04:41 AM
rmurer's Avatar
alright thanks all.
Old 5/8/14, 07:38 AM
CVH
CVH's Avatar
Originally Posted by db2797
You need to install this sensor if you want to measure boost: http://www.americanmuscle.com/aerofo...nsor-9612.html
No sensor needed on my 2013 Cyclone
The obd2 port sends all parameters
Old 5/8/14, 04:21 PM
racksteris's Avatar
Really
Old 5/8/14, 06:07 PM
CVH
CVH's Avatar
Originally Posted by racksteris
Really
Here are some shots.
Attached Thumbnails OBD2 port and boost-image-849504069.jpg   OBD2 port and boost-image-184856297.jpg
Old 5/8/14, 08:48 PM
rmurer's Avatar
I dont think its a true read out of boost.
Old 5/8/14, 10:15 PM
southcarolina12's Avatar
the stock map sensor is good to about 10psi or so. after that youll need a different map sensor.
Old 5/9/14, 02:11 AM
CVH
CVH's Avatar
What makes you think that?
Old 5/9/14, 08:57 AM
rmurer's Avatar
Maybe my assumptions wrong but without any FI shouldn't it show 0 boost?
Or if i were to install a legit boost gauge would it still show boost?
Old 5/9/14, 09:22 AM
spqr's Avatar
It should show a vacuum
Old 5/9/14, 09:30 AM
rmurer's Avatar
Im only curious because i recently just ordered and got this in the mail.
http://www.ebay.com/itm/130905669470...84.m1497.l2649
along with the android app.called torque it shows boost and vacuum
Old 5/9/14, 09:58 AM
CVH
CVH's Avatar
Im only curious because i recently just ordered and got this in the mail. http://www.ebay.com/itm/130905669470...84.m1497.l2649 along with the android app.called torque it shows boost and vacuum
Good luck with that. Those 10 dollar obd devices are garbage.
GoPoint makes a reliable auto power on/off , latency free dongle.
Try dashCommand. Much more advanced than torque.
Old 5/9/14, 10:08 AM
rmurer's Avatar
Works okay to monitor basic stuff.
I'm not using it to monitor boost but temps and stuff and it was what maybe 20$ total? I won't lose sleep over it.
I bought a legit roush boost gauge anyway.
Old 5/9/14, 11:10 AM
CVH
CVH's Avatar
Works okay to monitor basic stuff. I'm not using it to monitor boost but temps and stuff and it was what maybe 20$ total? I won't lose sleep over it. I bought a legit roush boost gauge anyway.
It doesn't work ok at all. I wouldn't leave it plugged in over night either. Have heard of them draining the battery.
IMO that would have been 20 bucks towards a good working model.
It's a learning experience.
Tip. It's cheap for a reason
Old 5/9/14, 12:07 PM
rmurer's Avatar
I tested mine works fine for what i want it to do. But please tell me more why I'm wrong.
Old 5/9/14, 12:13 PM
wheelman's Avatar
But it's been out of stock for a month!
Old 5/9/14, 03:00 PM
CVH
CVH's Avatar
Bummer, I purchased it about a year ago from Amazon.
Quick Reply: OBD2 port and boost
