Invisicord (Detector to mirror power tap) question
UPDATED: 4/30/2012
Received my Invisicords in the mail today. Thanks to you guys and this forum, I completed the install on Marilyn and Tori within 10 minutes. For the 5.0, blue is 12v and black/yellow is ground. Shove the pins from the invisicord in, and voila.
Now it's nice and tucked up and away from the center of the windshield. Easiest mod ever. LOL. Thank you again to everyone on this forum who contributed. You guys rock. Hopefully this helps others that were looking to do this as well.
Also, I finished the install on my Acura TSX as well
Folks... I have an Escort 9500ix (LOVE THAT THING)...did a search and saw 3 hits on this, but I just wanted to confirm the location of the 12V pin and the ground pin on our mirrors? I have Sync, but no camera.
When looking at the back of the mirror connector (tab on top):
12V pin/wire is the blue wire in the up-left most correct?
Ground is the black wire in the right most?
thank you.
I ordered 2 invisicords, and want to get rid of my power cord on my 9500ix.
thank you.
I have picture on this some where... I've done this and had wired the V1 in to the mirror. It's a green and white one and the black. I'll search again. I have this done in my truck at the moment.
Edit, If I do not have an answer in the amount of time you want, Pull the plug from the back of the mirror, turn key to the on position and take a volt meter and test them. If you don't have a volt meter, you can plug the ground into the black wire, and then test for the power source. I know it was the top corner, but I do not remember which side.
Wiring diagram I looked at says blue is hot at all times, and black is ground. I would pull connector and test, before I decided to cut into it.
http://iihs.net/fsm/?dir=710&viewfil...%20Mirrors.pdf
This is the wiring in my truck, I have a back up camera in the truck.
My power comes from a Green and purple, and my ground is black.
I don't have pictures of the mustang wiring. Sorry. It is the top left for power.
My cord comes in tomorrow I hope...will update thread then.
Don't worry bud... I ignored that guy from day one. His posts are routinely rude and off-topic. I just let him rant on. The ability to flex his limited vocab on the Internet is just too tempting to him.
Thx adrenalin. Keep him in line. He does this routinely to EVERYONE'S threads. It gets old.
Anytime John! I highly recommend the invisicord. Cheap effective and shipped fast. And as you can see, very easy to install.
Btw, get rid of that cobra. It has about 1/3 the range and effectiveness of the escort or v1. I had one, I know. It sucked. There's a reason v1 s and escorts cost 400-500 bucks. It really works.
UPDATED: 4/30/2012
thank you.
thank you.
Originally Posted by Jellowood
Looks good. I have a 9500 also. My question is how long does your mount stay connected to windshield? I bought the larger one from Escort and it works a little better but still falls down occasionally. Is it still possible to attach to sun visor?
