GT500 strut mount arrow re-orientation requires disassembly?
Hi, all. I want to re-orient the GT500 strut mount so the arrow points inward to gain a bit of camber. So I know if I need to rent spring compressors, will this require disassembly of the strut and springs? I know I'll need to lower the assembly from the strut towers. Thanks.
Just unbolt the four strut nuts lower and rotate mount. Reinstall and retorque to spec. No spring compressor needed.
That's what I was hoping for. Will I have to loosen the strut nut to rotate or will it rotate freely at full torque?
^ just the 4 bolts, lower, then turn 180
Great, thanks. Any idea on how much + camber I can expect?
