GT oil change, OOPS! almost...
Started to do my first oil change on the new GT, got my oil change stuff together, oil(5w20 mobile 1), motorcraft filter and drain pan.
A thought occurred to me as I crawled under the car to start, "how much oil does my drain pan hold?" Car holds 8 quarts total and since the filter isn't very large there must be at least 7 quarts in the pan if not a little more. Checked the pan and it has hash marks telling you the oil level drained out and it is only marked to 7 quarts, might do but might not, plus it would be full to the top and be a real PITA to move without spilling when full. So, I'm glad I checked it! Ended up sacrificing my car wash bucket to catch the oil drained from the engine. The GT isn't quite as big of a PITA to change the oil on as my '12 V6 was but is still a little bit of a challenge to do without making a mess. And has anyone else noticed that the filter on the car from the factory is slightly taller than the replacement motorcraft filter? Strange... _ |
get yourself one of those easy drain plugs.
changing oil on the pony is probably one of the easiest cars I've ever done. I can do everything in 30 to 45 mins, depending on how long I let the oil drain (drip....drip....drip....). Also, no mess. Zip loc baggie trick. Never ever a mess.
Originally Posted by Glenn
(Post 6640210)
I pull up to the service desk, give the service writer the keys, go get a cup of joe, walk out to look at the new Stangs and F-150's, and 30 - 40 minutes later I'm on my way.
I used to change my own oil, but for $39.95 I get a tire rotation, oil/filter, everything checked out, and I don't get dirty. As I have became more mature (re: older) I see more the advantage of allowing someone else get under there. :nice: |
Originally Posted by wanted33
(Post 6640253)
I used to change my own oil, but for $39.95 I get a tire rotation, oil/filter, everything checked out, and I don't get dirty. As I have became more mature (re: older) I see more the advantage of allowing someone else get under there. :nice: Can't say I blame you for not getting under the car, I like to do my own to ensure the oil I want goes in and at the right level... but I'll use my couple free oil changes from my dealership for sure ;) |
Originally Posted by dmichaels
(Post 6640258)
Don't run synthetic I assume based on $40 oil change?
Can't say I blame you for not getting under the car, I like to do my own to ensure the oil I want goes in and at the right level... but I'll use my couple free oil changes from my dealership for sure ;) My car OTOH, being the track-pack, needs 8.5 quarts of 5W50 full synthetic. So no matter what way I look at it, mine is about a $100 oil change... even doing it myself. |
^ yep. Cost is irrelevant when it comes to 1x or 2x a year changes for me. 100 bucks for some nice quality time with my car, plus Amsoil for her blood? Priceless. No one else touches my car...
1 Attachment(s)
Originally Posted by JScottGT
(Post 6640265)
Manual says Track Pack takes the same 8 quarts just like a regular GT. And my 2 gallon former wash bucket worked just fine. I do need to get myself a bigger funnel for filling the oil though, dripped a little and had to clean it up. |
1 Attachment(s)
Originally Posted by Ltngdrvr
(Post 6640273)
Why 8.5 quarts? Manual says Track Pack takes the same 8 quarts just like a regular GT. And my 2 gallon former wash bucket worked just fine. I do need to get myself a bigger funnel for filling the oil though, dripped a little and had to clean it up. |
Originally Posted by FromZto5
(Post 6640234)
(Post 6640253)
1 Attachment(s)
Originally Posted by steven46746
(Post 6640295)
Boss oil cooler
(Post 6640321)
This page is from the 2014 owners manual, says 8 quarts, Track pack or GT, just a different weight oil.
Originally Posted by wheelman
(Post 6640384)
Printing error? Looks like they fixed the cap vs manual (5w20/5w50) thing this year but maybe forgot to update additional volume needed b/c the instructions for adding a cooler said to use an additional half quart. Or maybe they just figured out eventually that the additional oil wasn't necessary.
Track Pack cars come with a supplement to the owner's manual where it specifies the different fluids and capacities.
Originally Posted by 14Glassback
(Post 6640399)
The only supplement listed on the Ford owner site is for the GT500 for the 2014 MY, nothing for the Track Pack. |
(Post 6640265)
The $39.95 "The Works" package at the ford dealer includes synthetic blend oil. Granted, that price is for up to 5 quarts of oil. With our cars needing 8, be prepared for the dealer to charge you for the extra 3 quarts.
ALL 14 TRACK PACK CARS COME WITH THIS SUPPLEMENT IN THE GLOVE BOX. AS DID THE 13 TRACK PACK CARS... OK... CANNOT GET POST FROM STEVEN46746 TO ATTACH... I AM SURE IT IS USER ERROR... JUST HAVE TO SCROLL BACK AND LOOK... :banghead:
(Post 6640695)
