Full Sized Spare Mount
Old May 10, 2014 | 03:14 PM
shaneyusa's Avatar
Anyone out there have a solution for mounting a full sized spare in the trunk when the spare tire does not fit in the wheel well?
I have bought a full sized spare that matches my wheels & tire size. Very glad to have it. It does chew-up a lot of trunk space, but I can live with that. Will make the next road trip less of a worry. Got a tire tote cover to keep things tidy. Really like the cover, cheap and very effective. Does a great job of protecting the trunk liner carpet and keeping the tire black off everything. Also should make it nicer to get the tire in and out of the trunk.
Now I just need to find a good easy way to secure the tire... Do not like it floating around back there, and also do not want it to become a missile if something bad happens. Besides that it moves around just running around town.
So, I have been thinking about good ways to tie the thing down. Thought about having someone weld a loop to the floor, like the one in the wheel well, and using the regular Ford hardware to bolt it down. Also been toying with some nylon tire straps, but not sure I like that one. So before I pull the trigger on something I thought I throw this out and see if there were any other good ideas from the community to put in a clean, easy to use, mount solution. Got any ideas or installs you would like to share?
Old May 10, 2014 | 05:14 PM
Ltngdrvr's Avatar
Why worry with the full size tire?
Get a shorter tire that will let it fit in the well, then if you need it in an emergency you just use it for the short distance to the tire store to get the flat fixed or replaced.
Old May 11, 2014 | 11:31 AM
RubyRedMCA_Beast's Avatar
I prefer full size spares. My last vehicle had a full size spare and it came in handy on a few occasions. I do a lot of highway driving and I wouldn't trust a mini spare for that. I see too many idiots doing 80 with their mini spare on the front of a vehicle. Scary.
Anyway, as far as bolting it down, I've got no ideas. Does it fit in the spare tire well or is it on top of the trunk mat?
Old May 11, 2014 | 12:52 PM
shaneyusa's Avatar
It is a little over 1/2 an inch too tall to go into the wheel well. So right now it sits on top of the trunk mat. Eats a lot of trunk space too, but I am glad to have it.
Attached Thumbnails Full Sized Spare Mount-img_0962_s.jpg   Full Sized Spare Mount-img_0963s.jpg
Old May 11, 2014 | 01:01 PM
Yeah it's nice to have that spare, but you're right, it's hard to lose all that space
Where'd you get that cargo net btw?
Old May 11, 2014 | 01:39 PM
What if you put it in the spare tire well anyway and just put the trunk mat on top of it? The trunk mats have a cardboard or wood backing don't they? Something to keep it firm. Maybe make some spaces to put around the edges around the tire.
Or do you mean too tall as in the diameter of the tire is too large to even fit in the hole?
Old May 11, 2014 | 09:02 PM
shaneyusa's Avatar
Ordered the cargo net through the Ford dealer. It is a Ford accessory. It is like this one...
http://accessories.ford.com/cargo-ne...tyle-9703.html
Old May 11, 2014 | 09:05 PM
shaneyusa's Avatar
Diameter of the tire is over 27.5 inches and so it won't go very far into the hole. Tried to see if it would fit, but it sticks up about 9+ inches above the trunk floor.
Old May 11, 2014 | 09:20 PM
sakol's Avatar
Try letting a little air out of tire so it will go all the way down.
Old May 13, 2014 | 09:41 PM
shaneyusa's Avatar
I will give that a try. Seems like a lot of ground to make up to get it in a tight space, but we will check it out.
Here is why I got a full sized spare...
https://themustangsource.com/f726/wh...-spare-529258/
Old May 26, 2014 | 12:15 PM
shaneyusa's Avatar
Well, dropped the tire pressure down to 8lbs and it goes a little bit further into the well, but not far enough. Still more tire out than in. This will not work with this size tire. 275/35R20...
Old Sep 30, 2014 | 07:35 PM
shaneyusa's Avatar
Bump -- So no other ideas?
Old Sep 30, 2014 | 08:10 PM
califsp's Avatar
full size spare
Got this wheel: http://www.americanmuscle.com/black-amr-18x8-0513.html
I fitted a 225/50R18 tire to this wheel and it fits in the trunk space just fine. Just an FYI: If your mustang is lowered make sure you get a jack that is lower than 4 inches when compressed so it will fit under the side skirts with a flat tire.
Old Sep 30, 2014 | 09:08 PM
silverstate777's Avatar
Have you seen the Receiver Hitch Tire Carrier option. Could be a temporary solution for road trips and free up some trunk space?
Old Sep 30, 2014 | 09:33 PM
wrkhrd's Avatar
I have a full size spare tire which I negotiated it at the time of purchasing the car. It is not matching but it is full size. Although it is an 18" but it clears my Brembo calipers and it only come up less than an inch above the trunk floor. Basically I didn't lose any trunk space. I like to have a full size spare since I don't like to be forced to pay for a tire at any price at any tire shop if I get a non-repairable flat. This is beside the fact that I travel a lot and I like to feel that I can go more than 50 miles with the repair kit.
Old Oct 1, 2014 | 05:11 AM
TripleBlack14's Avatar
Do the rear seats on a coupe fold down? Since they're pretty useless, at least on my convertible, why not display a full sized spare (with wheel and/or a tire cover) ala '65 Shelby style? You could use the spare tire well to keep tools, detailing kit, and other things out of sight and keep your trunk space nice and clean.
Old Oct 2, 2014 | 03:58 PM
kanine's Avatar
Wrkhrd, what's the tire size you have on your spare, it looks like it fits perfectly lengthwise.
Old Oct 3, 2014 | 07:55 AM
wrkhrd's Avatar
It is 225/50/18. It really sits there perfectly.
lowblustang00
Sep 5, 2015 12:18 PM
SMBJoshy
Aug 16, 2015 02:48 PM
ststang
05-09 Interior and Audio Mods
Aug 3, 2015 08:35 AM
