Disable Ignition Key-Door Open Chime on a 2011 ... YES !!
Over the years I have disabled the "Key in Ignition & Door-Open Chime" on EVERY Ford car I've owned.
On '04 and prior, it was always a Black wire with Purple dots or stripe on it that needed to be either cut or disconnected.
However on my 2011, there are 6 wires going to the switch and none were Black/Purple.
Did some googling and found a 2009 Ford Truck owner that said the color of the wire on his truck that activates the chime is Blue with a Gray stripe.
Well guys & gals, there is a Blue with Gray stripe going to the '11 Mustang switch and sure enough removing it from the plug eliminated the silly chime.
After disconnecting this one wire and plugging the switch back in I Started car pulled out into driveway. Ran the diaignostic checks, played with other features and nothing else seemed to be affected by the removal of this wire ... lights on chime still works with key in or out of ignition.
How to do it ...
Remove the lower dash plastic (2- 7MM hex screws at bottom of dash)
Remove Steel lower dash plate (4- 10MM hex screws)
Remove Steering Collum Plastic Halves (3- T-20 Torx Screws, then two plastic tabs that hold the halves together toward the front must be pried apart)
Unplug switch (press tab)
Remove red cover on end of plug (carefully pry out with finger nail; 2 small bumps hold it in place)
The Blue-Gray wire is the 3rd from the bottom, in the #5 slot
With a flash light aimed inside the plug opening, release the tiny plastic tab that hold the wire terminal in the connector with a small pick)
Push wire out the back of the connector and cover it with electrical tape
Reinstall the red cover (terminal tab may need to be bent back, be carefull I broke mine off !!)
Plug Switch back in and test
Reinstall everything else in reverse order ... whole job takes 5-15 minutes total. Worst part for me was getting the right side tab to release on the steering collum covers.
If you ever want to re-activate the Key-In-Ignition Chime, just remove the red cap again and push this wire back into slot #5 and it is as if you never did anything.
Sorry that pictures aren't the best, but it gives you an idea what your looking for.
Pic 1 shows the red cover partially removed
Pic 2 shows the wire haflway puched out of the connector
Pic 3 shows it plugged back in with this wire removed and hanging there (not taped yet)
Doug
How to do it ...
Doug
Thanks very much for posting this! When I wash my car I always like to leave my door open on my car so I can listen to the stereo and usually end up getting annoyed by the chime and just close it, but this could be a great solution. Please update this thread if you end up with any issues because of the wire being pulled!
You've never wanted to sit in your car with the radio on and the door(s) open ??
Or your doing interior cleaning / vacuming and you want the radio on ??
Or you are working on something where you need the engine running and you want to leave the door open rather than constantly opening & closing it ??
Another solution could be to just interupt this wire with a switch that you mount under the dash ... this way you can turn it off when you want it off.
People who just "drive" cars ... never wash or clean them or do any maintenance themselves I can see sayining the door buzzer never annoys them, if anything they are glad it's there as they would be constantly locking their keys in the car.
99% (if not 100%) of the people who hang out on this web site are NOT this type or person and like me either disabled this key chime on cars in the past or always wanted to know HOW to do it.
Doug
Doug
Doug
Doug
Just open the passenger door instead lol
Many times I have wanted this chime defeated, and the seatbelt chime.
I thought there was a way to turn these chimes off without actually physically disconnecting them?
The seatbelt chime can be disabled. Just look in your owner's manual and it gives you the steps. I did it on my '11
It is funny that they have a way to deactivate the SAFETY related seat belt chime, but god forbid they offer similar instructions to do the same with this non-saftey related anoyance.
I did ask the service department manager at the Ford dealer when I picked up the car if there was a secret procedure not shared with the general public to program it out and he said unfortunately no ... and that if there was he would definitely know about it as it would be something he'd probably do to his personal cars.
BTW ... just drove 20+ miles of mixed city / country roads and no issues so far.
Doug
Doug
He just released the pin and took it out.
Really easy to do if you are familiar with connectors and no damage occurs at all.
Did you guys even read the whole write-up?
I cut the black/purple wire on my SHOs (actually I just removed them from the ignition cylinder), but I didn't have to worry because they had a keypad on the outside - so it didn't really matter if I locked the keys in the car. In fact, I would do so frequently in order to not have to worry about losing them outside the car!
The mustang, not having a keypad, would give me pause when considering the same mod.
One possible side effect is that the lockout prevention circuit (known as "Smart Locks") won't function. The wire you're disconnecting is the signal that a key is in the ignition cylinder. The chime is disabled because the system never knows there's a key in the ignition. Unfortunately, it also won't know you've left your key when you use the door switch to lock the doors, so you could potentially lock your keys in the car.
