Bullitt Rims for a 2014 GT
I've been looking online at the Bullitt rims from AM. I was originally going to purchase Torque II from American Racing, but the Bullitt Rims stay true the Mustang. My question is has anyone here purchased rims from AM? Or should I buy from a local wheel shop?
I have this setup:
Black Bullit
The only issue that I had were the wheel weights were mounted too far inboard and they rubbed on the front calipers. I had to remove them and have the wheels re-balanced at a local shop.
Otherwise I have had no other issues with the wheels or tires.
Black Bullit
I have this setup: Black Bullit The only issue that I had were the wheel weights were mounted too far inboard and they rubbed on the front calipers. I had to remove them and have the wheels re-balanced at a local shop. Otherwise I have had no other issues with the wheels or tires.
Ordered a set of wheels form AM over Christmas. Wheels came well packaged, and were in great shape. They balanced up quickly. AM is a good company, with great customer service.
The Torq Thrust II wheels ARE the original "Bullitt" wheels. I'm not sure what you mean. That being said, don't get 20s if you live in an area with potholes (see TheDivaDanielle's posts on this).
actually the Torq Thrust D was the original.
everything else is just a copy.
I did end up with a few bent up wheels from the crappy local roads of Washington DC, in actuality they were basically all from the same pothole at once. To protect my investment better, I'm sticking with a 20" wheel, but having tires with more sidewall.
These are real 20x8.5 / 20x10 American Racing Torq Thrust M (for Modern):
My only advice is that if you're lowered like 1.5" or more don't run wider than like a 285 out back, and try to run a 35 or 40 series sidewall up front and no less than a 35 out back to protect the wheels from potholes.
actually the Torq Thrust D was the original. everything else is just a copy. I did end up with a few bent up wheels from the crappy local roads of Washington DC, in actuality they were basically all from the same pothole at once. To protect my investment better, I'm sticking with a 20" wheel, but having tires with more sidewall. These are real 20x8.5 / 20x10 American Racing Torq Thrust M (for Modern): My only advice is that if you're lowered like 1.5" or more don't run wider than like a 285 out back, and try to run a 35 or 40 series sidewall up front and no less than a 35 out back to protect the wheels from potholes.
