Battery tender ?
Old Dec 11, 2014 | 07:23 PM
Kestral's Avatar
Battery tender ?
I lost the directions to my old battery tender so I was wondering do I have to unhook the car terminals to the battery or can I just leave it connected and conect the tender right to each battery terminal? Is that a big no-no?
Old Dec 11, 2014 | 08:04 PM
Galaxie64's Avatar
You can leave them connected. That is why they have the quick disconnect in the line.
Old Dec 12, 2014 | 05:58 AM
Coyote5-0's Avatar
Don't they advise hooking the negative to ground, not the negative terminal?
Old Dec 12, 2014 | 06:56 AM
pressman43's Avatar
You can do it either way. I have had my tenders bolted to each terminal for many years with no ill effects.
Old Dec 12, 2014 | 07:56 AM
Kingstrider's Avatar
I leave my battery connected and clamp directly to the terminals.
Old Dec 12, 2014 | 09:24 AM
Coyote5-0's Avatar
Are you guys sure that's the best idea? I've always been taught to hook negative to ground when charging or jumping a battery.
Old Dec 12, 2014 | 11:11 AM
dsp's Avatar
dsp
Connect to an exposed metal area on the engine when jumping with another battery to prevent the remote chance of an explosion due to concentrated out-gasses from the dead battery and a spark near the battery when you make the connection and complete the circuit.
I always connect my charger before powering it up, so no chance of a spark.
Electrically the terminal and chassis are the same point. It is a negative ground system.
Old Dec 12, 2014 | 02:16 PM
I bought the additional cigarette plug n' play and just do it that way. Way easier in my opinion.
Good luck.
Old Dec 12, 2014 | 04:55 PM
dsp's Avatar
dsp
Good luck.
I have one of those on my BMW charger, it is easier. A little more of a pain to run the wire under the cover, though. But, I don't have to get to the battery so it's a good trade off.
Old Dec 12, 2014 | 05:04 PM
GrnT's Avatar
Ooooo cool. I gotta look for one of those.
Old Dec 12, 2014 | 05:18 PM
dohc97's Avatar
Good luck.
I use this myself. My car has been on Battery Tender for a month now
Old Dec 12, 2014 | 07:42 PM
skramblr's Avatar
Just following up on earlier comments. When jumping a car, the jumper cable will have a live voltage on it and it will spark when you connect it to the battery - thus the potential for explosion if the battery is out gassing. With a battery tender, they should be connected with the tender off - so no voltage and no potential for a spark. Then plug in/turn on to charge. So it is OK to connect it at the batter terminals
Old Dec 13, 2014 | 04:52 PM
Yup. Way easier and the quick connects make it easy if you want to fire up or move the car once and a while. My car has been connected for about a month too.
Old Dec 13, 2014 | 04:56 PM
This is the one I use Mark.
If you want the cigarette plug and play, you have to buy that seperately. I also bought the extension to make sure it will reach into the car.
http://smartercharger.com/products/b...multi-us-3300/
Old Dec 13, 2014 | 05:52 PM
GrnT's Avatar
This is the one I use Mark. If you want the cigarette plug and play, you have to buy that seperately. I also bought the extension to make sure it will reach into the car. http://smartercharger.com/products/b...multi-us-3300/
Tony I would like to find an end that would fit onto mine. It would make it easier. Yours is very cool though. I'm using a battery tender jr. But they don't make a lighter adaptor for it. I clamp it onto the battery.
Old Dec 14, 2014 | 11:43 AM
skramblr's Avatar
About the cigarette charger (AKA, power port) version - I think this is not compatible with all cars. A lot of new cars disconnect power from the power port when the car is off (it appears to be on a relay). I know our Focus disconnects, but the Mustang seems to be OK.
Old Dec 14, 2014 | 04:09 PM
Yes. I know it works perfect for the Mustang because this is my second year using it with the cigarette plug in. I also made sure it would work properly before being this specific brand of "smart charger".
Old Dec 16, 2014 | 07:14 AM
Coyote5-0's Avatar
Ok, so you are fine then hooking it up to the terminals. Good to know.
Old Dec 16, 2014 | 02:40 PM
Yeah,...that's the way I did it with the Hugger Orange SS.
Old Dec 16, 2014 | 05:56 PM
70monte's Avatar
I have my battery tender hooked up to the terminals and keep the battery hooked up to the car. I have it this way on a total of four vehicles and one ATV. On the ATV and the Ford vehicles, I leave the quick connect connectors on the battery clamps because they have bolt on assemblies I can hook the eyelets to. On the Chevy trucks, I use the clamps.
Wayne
