ball joint fitment problem - too big
I purchased Proforged ball joints for my 2010 GT, and when I tried to install them, I found that they are too big to fit in the hole in the a-arm. I couldn't believe my eyes and figured it must be my mistake somehow, but checking it several ways I find that they are indeed too big. Pics attached.
The part number is 101-10011, and I double-checked Proforged web site and it lists the same part. (I bought them from Rock Auto) Does anyone know what is the story behind this; and how do I make sure I reorder the right ball joints? thanks in advance PS -- yeah, I painted the a-arm red . . . after all the work to remove it and the bushings, I thought it should look different when I put it back in, LOLhttps://cimg6.ibsrv.net/gimg/themust...bd1765dc0b.jpg https://cimg7.ibsrv.net/gimg/themust...89f06c9888.jpg https://cimg8.ibsrv.net/gimg/themust...260a457e8c.jpg https://cimg9.ibsrv.net/gimg/themust...c8240694c2.jpg |
update -- I think this might be a "red headed step-child" problem with my 2010 . . . . I think the ball joints were upsized in 2011, and the ones I got are for the 2011+ cars; for my 2010 I need the 2005-2009 ball joint . . . does that make sense; is anyone else familiar with that?
Originally Posted by Bert
(Post 7042067)
On a side note the Moog # for the 2010-14 K500313 and the 2009 is #K500033 and going by the pics on Advance auto's web site the 09 does look smaller. |
hmmmm . . . makes me wonder if they changed the ball joints during the 2010 model year and maybe I got one of the earlier ones with the older/smaller ball joints
(Post 7042071)
I was looking around online to see if anyone had the actual size and could not find it. Was your car built before 8/2/09 by chance. Don't know if the difference was the ball joint, actual control arm or the control arm bushings but I got a different part number when I looked up the lower control arm. FITMENT DETAILS 2009 Ford Mustang GT (4.6L 281CI V8 FI VIN: H)
BTW CJ's has the Steeda Lowered ball joints listed for the 2005-10 for the X5's and 2011-14 for the X11's.
They also have the Pro Forged 101-10011 listed for your car, the 2005-09 is 101-10009. |
Bert I know you like track work so I was thinking it might pay you in the long run to simply put '11-'14 control arms on the car. A little more money, but you would have the safety advantage of a bigger ball joint and all new control arm bushings as well. If the shaft portion of the ball joint is bigger in diameter than your current ball joint then you would have to change the spindles or uprights too. Since you have a dial caliper that should be easy to find out. Good luck.
hey guys, thanks for the inputs
(Post 7042077)
. . Was your car built before 8/2/09 by chance. . . . I got a different part number when I looked up the lower control arm.
(Post 7042078)
Originally Posted by SilrBult
(Post 7042083)
I got the "right" ball joints yesterday and hope to get it put back together today, will post up later |
Glad to hear Bert :nice:
https://cimg3.ibsrv.net/gimg/themust...4e43d74821.jpg
To close the loop on this: yes, there are two ball joints for the 2010 model year; Rock Auto and most others have the wrong ones listed for my car. The early build 2010's had the same a-arms and ball joints as the 09's ; part way through the year they changed the a-arms and ball joints to be the same as the 2011 model year. I don't remember the date but I think it is posted on here somewhere. Here is a picture of the old ball joint, the correct (smaller) new ball joint, and the later version of the ball joint. |
You can use the bigger ones on your 2012 when you get it.:nice:
