2013 Mustang Headlights on a 2010
I tried two ways. One i disconected the ground from the high beam and it worked fine exept the high will not work when the turn signal is on... The other way i disconnected the ground from the drl. Which the high beam works but the flashback did not work
Found my issue. the headlight assembly uses a shared ground. so when I connected both the high beam and DRL and connected my Morimoto switchback drivers the drl would not turn off. I disconnected the High ground and the switchback works so does highbeam. The issue is when the turn signal is on the highbeam does not work. I am guessing the switchbacks cut the ground when in use that is causing the issue. How do I get the highbeam to work without affecting the switchback. is there a way to get the switchback to cut power not ground.
2013 HID headlights using custom harness to connect to 2011-2012 nonHID
I want to thank LEXiiON, ebalderas and 5.0verkill.
Below are my findings in my quest to build a harness. So I hope this helps others make there own harnesses. all parts were purchased on eBay. except for wrap solder shrink wrap harbor freight.
Pin 1 Low beam
Pin 3 DRL Power Full
Pin 5 DRL Power Dim
Pin 8 Ballast Ground
Pin 10 Power Ballast
Pin 12 Power High beam
Pin 14 Ground
Using Motocraft WPT 1357
I wired pins 1 and 10 together for power and pin 8 for ground to connect to the morimoto harness ballast plug using a male 9006 pigtail
I wired pins 3 power DRl 9006 pigtail to connect to Diodedynamics DS1 switchback driver
Did not use pin 5 drl power dim
Connected pin 12 power high beam and pin 14 ground to male 9006 pigtail. To connect to morimoto harness high beam plug.
For the turn signal I used a 7444 pigtail and connected to a 9006 male pigtail to connect to Diodedynamics DS1 switchback driver(Output used ground and yellow for turn signal and the white alone since headlight uses common ground for DRL). I first connected 7444 to 3157 to figure which two wires made turn signal flash since you do not use the other wire(used yellow and ground input).
I connected the 3157 directly to the switchback since this will connect to old turn signal bulb. Remember if it does not work rotate plug.
I ran a power wire from fuse 39 using a fuseblade to power switchbacks which in turn powered DRL
harness diagram
Materials needed
8 WIRE PIGTAIL MALE 9006 HB4 ONE HARNESS CERAMIC HEADLIGHT REPLACEMENT PLUG SOCKET
1 Small ACS-J Add A Circuit Piggy Back Pluggable Standard Blade Tap Fuse Holder
1 Morimoto MotoControl Bixenon: H13 9008 Harness TRS
2 Motorcraft WPT1357 Headlamp Connector
2 Diodedynamics DS1 switchback driver
2 Pre Wired Heavy Duty T20 Sockets Plugs Connectors Wiring Harness 7443 7444 992A
2 WIRE HALOGEN MINIATURE PIGTAIL MALE 3157 3457 TWO HARNESS REPLACE CABLE LAMP
Misc
Heat shrink
Split tube wire wrap 3/8
Solder
Below are my finished products
turn signal with morimoto switchback drivers(old photo use Diodedynamics DS1 switchback driver wired )
turn signal bulb harness
pigtail harness
9006 connectors connect to switchback and morimoto harness
16 pin connector
Pin 1 Low beam
Pin 5 DRL Power Dim
Pin 14 Ground
harness diagram
Materials needed
Misc
Heat shrink
Solder
pigtail harness
16 pin connector
I know this thread has been dead for awhile, but it still helped me out a bit.
Anyway I found a guy that actually makes this wiring harness. It's a plug-n-play 2010 Halogen to 2013 HID with DRL's, and takes about 90-120 minutes to install.
You can find him at:
Facebook Post
Connectors and lack of support of Morimoto
Cheers
I'll appreciate any help in this matter
Morimoto connectors
Mustang 2014 connector( there's also another small one of the turn signal)
Digital_Synapse
05-09 Exterior Modifications
12
2/6/08 03:26 PM
