'11 new wheels/315's
Finally got my Forgestar F14's and Conti ExtremeContacts put on yesterday.
275/40R20 Front on 20X9 +40 315/35R20 Rear on 20X11 +53 Very tight fit, but no rubbing. Rear tires do touch the Bumpstop pads when the rear-end is at full drop, but no problems when loaded. http://i98.photobucket.com/albums/l2...r/71bbbddd.jpg http://i98.photobucket.com/albums/l2...r/416be664.jpg http://i98.photobucket.com/albums/l2...r/59033c9c.jpg http://i98.photobucket.com/albums/l2...r/0180d10f.jpg |
:drool:
I love how aggressive these rear offsets are getting, it's like an eyegasm |
IMO it looks nice but it is a bit too much. It is very nice to know where the limit is. 28 inch tall narrow tires up front would give it a good drag strip look.
Your tires are 2.4" wider and 1.6" taller than stock so you will have to adjust your speedo some. TED |
Or if he's lucky his speedometer was off enough before the new tires that with them it's dead on accurate :heh:
That's how my truck was, when I went from 235/75R15s to 31x10.50s (same as 265/75R16) |
The Brenspeed tune I ordered is adjusting the speedometer.
can you post a picture of the profile of the car so we can see what the wheels look like and the car as a whole
Ryno, having a dilema here as to whether i'll go with 295's or 285's for the rear with my SVT PP wheels. Can you provide some more photos from the side if you can. My question is how will 275/40's handle on 9 " wheels !
My preference would be to go with 295/30/19's rear with 10" wheel, and 255/35/19's for the front with 9" wheel. Nice ride by the way.:nice: |
Originally Posted by m4reapr
(Post 5974027)
Here's another forum where someone put on 285/35/19 on the Brembo rims.
http://www.moddedmustangs.com/forums...o-19-rims.html Stock 255/40 are about 27 inches tall and these are about 26.8. Almost the same. The 295/35 would be 27.1 inches but from looking at tirerack there are a lot less choices to pick from; one. TED |
Originally Posted by Ted in Olympia
(Post 5974043)
Here's another forum where someone put on 285/35/19 on the Brembo brake rims.
I wanted the tire to bulge past the wheel a bit. The rears are 11" wide.
I've just seen a few pics with guys running 285/40/19 back and 255/45/19's front.That seems to give the tire a bit more sidewall and an overall better look IMO.
Nice ***!
(Post 5974122)
Originally Posted by erickburke
(Post 5974126)
Nice ***!
Originally Posted by rsb5772
(Post 5973853)
275/40R20 Front on 20X9 +40 315/35R20 Rear on 20X11 +53 Very tight fit, but no rubbing. Rear tires do touch the Bumpstop pads when the rear-end is at full drop, but no problems when loaded. http://i146.photobucket.com/albums/r...g/_1012153.jpg |
Looks familiar.... :D
wow, lots of wheel and tire
don't know if you plan to lower the car but if you can end up with the stance that 908ssp's car has it will look outrageous thx for the pics |
Looks terrific. Did you weigh your assembled wheels and tires?
Mine are. Stock wheels and tires 255/45-18, tire and wheel 56lbs Steeda front 9.5" wide 275/35-20, tire and wheel 61lbs, +5lbs more than stock Steeda rear 11" wide 315/35-20, tire and wheel 69.5lbs, +13.5lbs more than stock |
SWEET !!!! :nice:
| All times are GMT -6. The time now is 05:01 AM. |
