'11 new wheels/315's
Finally got my Forgestar F14's and Conti ExtremeContacts put on yesterday.
275/40R20 Front on 20X9 +40
315/35R20 Rear on 20X11 +53
Very tight fit, but no rubbing. Rear tires do touch the Bumpstop pads when the rear-end is at full drop, but no problems when loaded.
IMO it looks nice but it is a bit too much. It is very nice to know where the limit is. 28 inch tall narrow tires up front would give it a good drag strip look.
Your tires are 2.4" wider and 1.6" taller than stock so you will have to adjust your speedo some.
TED
TED
Or if he's lucky his speedometer was off enough before the new tires that with them it's dead on accurate
That's how my truck was, when I went from 235/75R15s to 31x10.50s (same as 265/75R16)
Ryno, having a dilema here as to whether i'll go with 295's or 285's for the rear with my SVT PP wheels. Can you provide some more photos from the side if you can. My question is how will 275/40's handle on 9 " wheels !
My preference would be to go with 295/30/19's rear with 10" wheel, and 255/35/19's for the front with 9" wheel.
Nice ride by the way.
Here's another forum where someone put on 285/35/19 on the Brembo rims.
http://www.moddedmustangs.com/forums...o-19-rims.html
Stock 255/40 are about 27 inches tall and these are about 26.8. Almost the same. The 295/35 would be 27.1 inches but from looking at tirerack there are a lot less choices to pick from; one.
TED
TED
Here's another forum where someone put on 285/35/19 on the Brembo brake rims.
TED
TED
Thanks.
Looks terrific. Did you weigh your assembled wheels and tires?
Mine are.
Stock wheels and tires 255/45-18, tire and wheel 56lbs
Steeda front 9.5" wide 275/35-20, tire and wheel 61lbs, +5lbs more than stock
Steeda rear 11" wide 315/35-20, tire and wheel 69.5lbs, +13.5lbs more than stock
Mine are.
